Change access code from ford pass?
Pitbull2o08
Ohio
Is there any way to modify my access code from the ford pass app or website.
I already use a modified version, but that’s probably compromised now. I am away from the truck at the moment, so can I change it via these other routes?
Thanks
Thanks
No, you cannot. You must be at the vehicle to do so.
You can add codes (at the vehicle), and delete codes, but the original factory code will still work.
Pitbull2o08
Pitbull2o08
Ohio
This can be done at the keypad in addition to on sync, correct?
Pitbull2o08
Pitbull2o08
Ohio
Ford F-150 Lightning Change access code from ford pass? IMG_5084
