Some Lightning settings have a hard time being remembered?
Lightning Bronson
Jansen
Greater Toronto Area
F150 Lightning Lariat
Snow Removal, Landscaping
What's up with that?
I'm on 10.1.1 and I'm noticing that the truck is forgetting I set the truck to 24 Hour mode; Trip Log (a feature I like as it shows where I've traveled to) seemingly disables itself as well, which completely kills driving history on the map.
No, there's only my own profile in the truck and it's not in Guest mode.
Is anyone else noticing this as well? Ford please fix?
Caduceus
Evan
OR
2023 F-150 Lightning XLT
I have had the same issue with the 24 hour mode. I called Ford support and they weren’t able to help. They recommended that I take it in for service ?ā€ā™‚
i did learn recently that you can just tap on the time in the main display and it takes you to the screen to change it instead of going through the settings menu.
TMND
usa
Lightning
ag
Every single time I want to adjust the charge limit from the truck I have to do it twice. The first time it doesn’t save it.
also, (this was while fast charging) why can’t you adjust your charge limit from the app for that?
Lightning Bronson
Jansen
This is mindblowing news. Thank you!
Lightning Bronson
Jansen
Which software version are you on? I haven't noticed this with charging as of yet; we absolutely should be able to do more with the app, including setting charge limit.
Might give it a try tonight.
TMND
usa
Lightning
ag
Oh, I’ll have to try to remember to check when I finally go outside to drive to my sister’s for the holiday. Ironically, you can’t see that in the app. ?
COrocket
F-150
10.1.1 did indeed break the 24 hour clock for me AGAIN. @Ford Motor Company It’s unbelievably frustrating when these bug fix software updates break as many things as they fix….
Lightning Bronson
Jansen
I noticed that it didn't remember the setting *again* earlier this arvo and I went into vehicle -> general settings, and it fixed itself back to 24 hour mode, as if I threaded the truck software ?
Trip Log also still disables itself frustratingly.
Ford please fix ?
Ish
ā€˜23 Lariat ER
What is even more frustrating is it appears to believe it is in 24 hour mode ante meridian and when it hits 1200 it doesn’t know what to do so it reverts to post meridian time. Every. Single. Day. Almost feels like a lemon law day each day ?
