Will 35x12.5 BF Goodrich Ko2 tires fit with 2” level kit?
LuisCarrillo91
Luis
Las Vegas
2021 Ford F-150 XLT FX4
Can you fit BF Goodrich Ko2 35x12.5 on a 2021 f150 XLT with a 2 inch readylift? I’m trying to see if this will work without modifying anything.
Thank you in advance.
wayne
wayne
northern calif
2021 f150 platinum loaded, 2013 raptor
me too. i like the K02's they are quiet
LuisCarrillo91
LuisCarrillo91
Luis
Las Vegas
I should also have added That with these tires I’m looking to match them up with method wheels 18x9 with a 25 offset
Asphaltman
Salt Lake City
2021 F150 (produced 2/11) 2018 F-150 1997 F-250HD
Entrepreneur
I don’t think so but you might want to still check. Im running a 295 60 r20 and it’s 33.9 tall x 11.6 and I clear with just a 1/2”. I’m using a 20x9 wheel with a +20 offset. Factory offset is +44
LuisCarrillo91
LuisCarrillo91
Luis
Las Vegas
I wanted to try but the tire shop told me I had to order the tires and had to keep if they don’t fit. So I’m trying to see if anyone else has tried this setup first. Your setup sounds great. I might have to go that route If this doesn’t work.
Asphaltman
Salt Lake City
Entrepreneur
I just went my route because it was the size that ready lift had recommended. I’m pretty happy with how it turned out.
https://www.f150gen14.com/forum/threads/fuel-rebel-6.2704/
https://www.f150gen14.com/forum/threads/rapid-red-f-150-2021-club.209/post-41935
LuisCarrillo91
LuisCarrillo91
Luis
Las Vegas
Can you fit BF Goodrich Ko2 35x12.5 on a 2021 f150 XLT with a 2 inch lift? Anyone tried it?
Corsini77
VA
2021 f150
I would think not. I have a 6 inch BDS lift with 325/60-20 Ko2’s. Slight modification up front was needed to fit. Rubbed on the bottom air dam up front (plastic piece across the bottom of bumper). The 325/60 is slightly bigger than a 35x12.5 tire, but with only a 2 inch lift, I would guess it would not fit.
LuisCarrillo91
LuisCarrillo91
Luis
Las Vegas
Thanks. Yeah I’m thinking I might have to go a bit smaller.
LuisCarrillo91
LuisCarrillo91
Luis
Las Vegas
That looks amazing! Exactly what I’m looking for!! Any rubbing at all? Did you have to do any modifications to make it work?
35x12.5 open country a/t III, with a 2” level no crash bar removal.
LTDXLT
Lance
2021 Space White F150 XLT
Is your side emblem all blacked out, and if so, how did you get this look?
eurofan85
Cody
Denver
2021 Lariat F-150, 2018 RR AB, 2018 GT2RS
Oil & Gas
the tiniest bit of rub nothing bad and it’s only when I have the wheel cranked all the way to the left and I’m in reverse but it’s not bad enough to bother me.
eurofan85
Cody
Denver
Oil & Gas
Haha plasti dip but I already took it off. Waiting for painted ones to be released
