Towing ~7000lb Tritoon/trailer
Shawn
2021 Ford F-150 King Ranch 4x4 Ecoboost 3.5L
This truck handles my tritoon so much better than my 2017 Nissan Titan. The Titan Platinum Reserve rear suspension sagged. This truck sits level and feels so much better on the road.
Ford F-150 Lightning Towing ~7000lb Tritoon/trailer 3EC93E61-2CC1-4806-9C61-201D689455A8
mnstang
Nick
MN
2021 F-150 Lariat PB Leadfoot
US Gov
Looks great!
cogatti
david
2010 King Ranch
NICE BOAT......AND OF COURSE EXCEPTIONALLY NICE TRAUCK!!!!!!!
DHerod
Dan
CO
2004 Yukon Denali
High School Teacher
@BuiltFordTough - do you know the tongue weight of your trailer & boat? I'm looking hard at buying an F150 soon and need to tow a 6500lb dry weight travel trailer. I installed Timbren suspension parts to keep my current 2004 Yukon Denali from sagging. They work great...I'm just trying to figure out if I'll need to add them once I jump off the cliff and get a 150. Thanks!
Ryan
Clay WV
2021 Ford F150, 2004 toyota sequioa, 2010 toyota corolla, 2000 Jeep TJ
Banker
Fantastic setup! looks great. beautiful boat
meyer_22
Kurt
2021 F-150 4x4 Hybrid, Lariat
Looks amazing! Would love to know what your setup is for hitch...
Shawn
@meyer_22 I’m using a ball mount with a 2” drop. Since this photo was taken I have flipped it which gives about a 1” rise to help the boat ride more level. The boat trailer has a surge brake so I haven’t bothered with a weight distributing hitch. I do have the Max Tow package.
Shawn
@DHerod my tongue weight is reported as 660 lbs on the trailer, but that doesn’t include weight from coolers and supplies added to the boat. I would consider a weight distributing hitch for a travel trailer. I don’t have one for my boat trailer since it uses a surge brake.
DHerod
Dan
CO
2004 Yukon Denali
High School Teacher
@BuiltFordTough. Thank you very much for the info. My tongue weight is listed at 610 lbs and I do have a WD hitch that we use with our current '04 GMC Yukon that I assume I'll be able to use with the F150 with no problems. Your response really helped me a lot. I'm going to stop worrying about having to add any Timbren (or other) suspension parts to prevent sag. It's always so nice to cross something off the 'what about' list :)
Pedaldude
Arizona
Ford F-150 Lightning Towing ~7000lb Tritoon/trailer 10879E19-00C7-4FDA-BF25-D5EF717601BA
I’m currently looking into getting a double axle trailer for my truck. Reading the manual, I can’t find anything mentioning a weight distributing hitch being required, or even anything with a tongue weight limit other than on this page. With a class 4 hitch, some manufacturers allow up to 1,000lbs of tongue weight.
I know in some manuals and even stickered on some hitches is a 500lb limit, with 800lbs weight distributing but apparently that’s for what’s called a Class III/IV hitch.
I have the Max Tow and HDPP, so my GVWR is 7850lbs with a GCWR of 18300lbs, Ford’s tow chart lists 13,000lbs as the maximum loaded trailer weight for conventional towing. Then, at the bottom of the page, in the 2021 towing brochure, there is mention of a weight distribution hitch for all factory installed hitches, including the Max Tow option, which is supposed to be a class 4 hitch. Sure enough, there is a sticker on mine, though not exactly obvious unless you crawl underneath.
Ford F-150 Lightning Towing ~7000lb Tritoon/trailer A926C29C-4B54-4F2E-BAA0-0BC999771A1E
Ford F-150 Lightning Towing ~7000lb Tritoon/trailer A3453F41-FB6D-4EFA-A35E-3337A271B4D7
So does this mean that the factory installed Class IV hitch on Max Tow isn’t a true Class IV hitch but more of a Class III/IV? It kind of sucks that if you want to tow 6,000lbs, that you have to use a weight distributing hitch to stay kosher, especially since the WD hitch adds 100lbs on its own.
https://www.truckspring.com/towing/trailer-hitches/hitch-classes.aspx
Meanwhile, an aftermarket Class III hitch has a better non WD capacity than the factory “Class IV” hitch:
Ford F-150 Lightning Towing ~7000lb Tritoon/trailer 9E6FFBC3-BE81-4CCE-8261-30EB93F9A352
Just another example of the shell game that is Ford’s payload and tow rating system.
meyer_22
Kurt
Thanks much. I have a Powerboost Full Hybrid with Max Trailer Tow, and also will be pulling a 26ft Tri-Toon with a 300HP engine. Was interested in whether or not you had the weight distributing hitch or not. Have you used the pro trailer assist, and if so was it a pain to place the sensors on the trailer?
Im also trying to decide what ball mount I get, not sure if I want to go with one with multi positions or just a standard drop and flip like you did if needed...
Arcteryx
RJ
Wisconsin
2021 XLT FX4 Lead Foot Gray
That seems odd. I need to look at my truck now. My tacoma i just traded in had a 500 lb max tongue weight without WDH. Hard to believe this hitch is rated the same. Anything over 5000 lb for a TT i would use a WDH regardless just because of size. Anderson WDH only weighs 53 lbs and doesn't give you the bulk of the friction bar style as well.
Zarn99
Jason
Spearmint01!
2021 F150 XLT FX4 302A
I'll be towing this Tuesday. Just set up the hitch today and am happy it sits level. I do have timbrens installed just incase. 8200lbs dry.
Ford F-150 Lightning Towing ~7000lb Tritoon/trailer IMG-20210508-WA0001
Ford F-150 Lightning Towing ~7000lb Tritoon/trailer IMG-20210508-WA0003
Sundancer330
2021 F150 XLT, FX4, Velocity Blue
Do you have any payload left, at 8200 pounds that's 800-1200 tongue weight and most of these trucks top out at 1500 pounds payload some as low as 1200, be careful.
