Aftermarket Wheels / Tires Thread
mason1646
Mason
Van Meter, IA
2017 F-150 Limited
Thanks, I looked the Wild Willies up and they have a similar one (in fact larger tire 295/60R20 which is a total 33.9in diameter) and it fits fine with the Fox 2.0 Kit
Would love to see more 17 inch rim 34 inch tire aftermarket builds if anyone has them
The fat sidewall is where its at for me... it looks great
In case anyone is interested this is the benchmark I am referring to above:
Smroepe
Shane
Raleigh, NC
2021 F150 XLT Sport SuperCrew
Got mine leveled and mounted today.
ProComp 2.25” level
Fuel siege 20x9 +1offset
295/55/r20 Nitto Ridge Grapplers
- a little more poke than I intended but it looks mean! No rubbing at all
Ford F-150 Lightning Aftermarket Wheels / Tires Thread F92C05D9-5E8B-4FD0-AA99-B188B4ED0161
Ford F-150 Lightning Aftermarket Wheels / Tires Thread 3403A4CD-D1B4-4961-AF84-82834B2C1086
Ford F-150 Lightning Aftermarket Wheels / Tires Thread 97B7F6B9-1437-4382-B360-2EAEC64A4627
BDUBSpeed
North Dallas
2021 F150 Lariat
Great looking truck
Reading some people say there are concerns with the 2.25" lift (seeing as its a 2020) and others seemingly having no problem
Whats your thoughts/experience?
The 2021 specific is a 2" I wonder if the 2.25" 'issues' are an urban myth
Thanks
So far I haven’t had any issues, nor have I noticed any difference in the ride.
DSIreppin
Blake
21 F150, Audi e-tron
DSI custom vehicles manager
I do upfits for work. We just did this 21 STX. 2.5" level kit with 20" pro comp and 35x12.5 yoko. Crew cabs 18+ all have rub issues with 35s because the front crash bars. You can pry and adjust them to clear.
Ford F-150 Lightning Aftermarket Wheels / Tires Thread 20210429_104646
tbell_1
Troy
Ontario, Canada
2021 502A Lariat on order, current: '19 501A
Maintenance Planner
These Assualt's have been my fav for years!! seriously considering putting some on my 502 when it comes in...
2” leveling kit, 20x9 zero offset, Fuel assault wheels, and 33x12.5 Nitto Ridge Grapplers. No rubbing
NiftyF150
Tony
2021 F150 XLT Sport Leadfoot Gray 302a Ecoboost
Maintenance Supervisor
Macarrra
Tim
2021 F150 XLT
That’s exactly what I went for as well...
Thanks Nifty
Can you please confirm:
-Tire size
-Rim size (including offset)
-Choice of lif or level
Many thanks I'm pot committed now and parts will arrive soon I hope I made the right choices
NiftyF150
Tony
Thanks Nifty
-Tire size
Tire Size: 285/75R17 10E Nitto Ridge Grappler
Rim Size: 17x8.5" ET0
Level: Supreme Suspensions 2.5" leveling puck
I hope this helps! I absolutely love the setup and have zero regrets.
grock
BC, Canada
2021 F150 Platinum in Star White
Just got my wheels on. Fuel Rebel 6-Anthracite / Black. BFG KO2 295 60 R20 +20 offset.
I like them, but not sure about the rear poke. I dont want to spray crap down the side, and these appear to poke out than previous setups I have ran. More of an issue with the rears than the front.
What are decent options?
-Fender Flares, Ive never done these because I hadn't ever wanted to drill....should I look at this option though?
-Ford OEM mudflaps. Im not sure this will provide enough coverage
-Clear Bra film?
LOVE the look of those wheels on your truck!
Curious if you had any issue with rub at all? Also did you need to do any modification to the air dam or remove the front crash bar?
I've got the same setup in Oxford White on order right now so I'm hoping to get the wheels and level kit sorted ahead of time.
Asphaltman
Salt Lake City
2021 F150 (produced 2/11) 2018 F-150 1997 F-250HD
Entrepreneur
Thanks! Zero rub….except initially on the front passenger mudflap I installed. I just sanded it down a bit and it’s no longer an issue. Not sure why on that one had a slight rub. Easily clears the front end stuff though. I’m super happy with this lift, tires and wheels….just wished I was as happy with Fords build quality.
Here is the thread with the truck details.
https://www.f150gen14.com/forum/threads/2021-f-150-lariat-502a-level-tires-and-wheels.2789/
BoostedECO
New Jersey
2021 Ford F-150 XLT FX4
Anyone have any luck with 20x9 +1, on a 295/60/20. I know Wild Willies does it a lot and they look nice as hell, but anytime he does that set up he never mentions if any trimming or crash bar mods are involved. And whenever you comment on his U tube channel no response.
petervenkman
ohio
'21 Lariat Powerboost
2.25" Readylift Level, 20x9 Fuel Rebel 6 with +1 offset, 295/60/20 BFG KO2 tires. Had to remove the front crash bar and trim the lower valence plastic just a little, but a 34" tire fits.
according to willtheyfit.com, this is pretty close to what I am shooting for. same amount of poke and diameter, cept mine will probably be on 18s (Fuel Shok).
can you post a picture from behind to show the poke? or a quick video walk around?
much appreciated!
