Needed: torque values for the Lightning ER front and rear shock mounting bolts.
21st Century Truck
Martin
Folks,
I'm replacing my OEM shocks front & rear after 76 thousand miles... at least one shock is leaking oil, and "why not" after this mileage on the OEM shocks.
I'll be using the Eibach shocks for my Lightning ER, and per EIbach suggestion I'll be keeping the OEM springs as I do not care to "level" the truck.
Anyone who's DIY replaced the front and rear shocks, or anyone who has the Ford shop manual handy with this information, the torque values for the top and the bottom mounts, front and / or rear will be very much appreciated!
Side note: the pretty reliable. friendly local Ford dealer maintenance shop told when I was pricing options out that the front shock replacement is more involved on the Lightnings than the rear shock replacement, and they bill 4 hours for the front job labor vs. 2 hours for the rear job labor because of this. I've replaced shocks on a few of my former cars so I can see that... any comments from DIYers are welcome.
21st Century Truck
21st Century Truck
Martin
Just replaced mine with Eibach shocks… (you do Not need to remove front brake calipers, rotor, backing plate, or axle shaft nut) Hope this helps.
Ooooh You have made my day! A pizza and a sixpack of choice on me when we have a chance to meet!
21st Century Truck
21st Century Truck
Martin
380 foot-pounds? Wow that is pretty tight on the rear shock's bottom mount. I really, really appreciate this info.
What are Your driving impressions now with the Eibachs all around and the Ford OEM springs? Also, how many of the OEM shocks were blown or leaking at their replacement?
Itaintfastenough
Woody
Grandview Texas
2020 Transit Connect, 2023 Lightning Pro ER
HVAC Contractor
Well, it was the highway speed porpoiseing (rebounds)after encountering a minor dip that prompted me to replace them… my mileage is low at just under 15K, and three out of four OEM shocks had lost their nitrogen charge. Even backing out of my shop, with a 1-1/2” drop down from slab to ramp caused a couple of rebounds… That’s all gone with the Eibachs, and was the first thing I noticed. Highway speed dips are now smoothed out, with an overall improved feel one would expect from a quality shock. I’m running stock size Michelin tires with aftermarket 9and3 wheels with stock offset (+44) and stock ride height. Yeah, I agree, that bottom rear shock nut (30mm socket) is a tough one to break free and tighten. Had to us my 3/4” torque wrench rated up to 600ftlbs to tighten it. Caution! Make sure you support the rear swing arm when doing so! Also, don’t get frustrated when jacking up the rear coil over assembly to align with the bottom bolt hole… I wound up using a 1x1 square tube (about 6” long) between the bottom shock mount and swing arm to help keep it from being pushed to the rear while jacking it up. I did however experience frustration when I was finished, and putting up my tools, that I noticed a rear shock “bump stop” sitting on my workbench! Had to pull that rear shock assembly out and dismantle it again..😡 It’s not that hard to do, take your time… it’s worth the time and $ invested… Good luck! 🤗
21st Century Truck
21st Century Truck
Martin
... putting up my tools, that I noticed a rear shock “bump stop” sitting on my workbench! Had to pull that rear shock assembly out and dismantle it again..😡 It’s not that hard to do, take your time… it’s worth the time and $ invested… Good luck! 🤗
Oh I've stuff like that ha ha :crackup: Back in my younger and foolish years I and a friend reassembled my proudly bought used Kawasaki's camshaft 90 degrees out of phase, and "test-cranked" it with a wrench while the engine was still on the work bench. When it didn't quite rotate fully, we of course backed it up and, er... applied force like only two 20-somethings can do. THAT funny experiment meant two more new exhaust valves and another head disassembly / reassembly.
Itaintfastenough
Woody
Grandview Texas
HVAC Contractor
It’s things like that that stay burnt in our memories… so that we never repeat them again… it’s how we learn the hard way!🤗
21st Century Truck
21st Century Truck
Martin
Hey Woody,
The rear Eibach shocks have been on for a week and over 1 thousand miles now. I like the noticeable road holding improvement. Your information schematics were a critical part of the install. I ran out of time to do the front shocks that day, but the Army auto craft shop I used had the yuuuge Gigantor torque wrench and some very useful transmission support stands for that 380 foot/pound rear shock bottom bolt, and that was what I had focused on to get right.
FYI - because of the already higher mileage on my Lightning (78 thousand+ miles now) I now decided to also replace the front endlinks (potential worn endlink joints??) and also the upper control arms on the front end, all with greasable quality aftermarket units. I might as well do the work while I'll be replacing the front shocks with the Eibachs. I decided to just upgrade the upper control arms to better aftermarket UCAs with their new ball joints rather than struggling to break the old ball joint tapers free in the OEM UCAs.
So can I ask You for the torque values for the upper control arm wishbone ends on the front end? Much appreciate the info in advance!
Itaintfastenough
Woody
Grandview Texas
HVAC Contractor
Hey Woody,
Here ya go… hope this helps!
Ford F-150 Lightning Needed: torque values for the Lightning ER front and rear shock mounting bolts. IMG_5130
Ford F-150 Lightning Needed: torque values for the Lightning ER front and rear shock mounting bolts. IMG_5127
Ford F-150 Lightning Needed: torque values for the Lightning ER front and rear shock mounting bolts. IMG_5128
Ford F-150 Lightning Needed: torque values for the Lightning ER front and rear shock mounting bolts. IMG_5129
Ford F-150 Lightning Needed: torque values for the Lightning ER front and rear shock mounting bolts. IMG_5131
Ford F-150 Lightning Needed: torque values for the Lightning ER front and rear shock mounting bolts. IMG_5132
Ford F-150 Lightning Needed: torque values for the Lightning ER front and rear shock mounting bolts. IMG_5133
Ford F-150 Lightning Needed: torque values for the Lightning ER front and rear shock mounting bolts. IMG_5134
Ford F-150 Lightning Needed: torque values for the Lightning ER front and rear shock mounting bolts. IMG_5135
Ford F-150 Lightning Needed: torque values for the Lightning ER front and rear shock mounting bolts. IMG_5136
Ford F-150 Lightning Needed: torque values for the Lightning ER front and rear shock mounting bolts. IMG_5137
Ford F-150 Lightning Needed: torque values for the Lightning ER front and rear shock mounting bolts. IMG_5138
Ford F-150 Lightning Needed: torque values for the Lightning ER front and rear shock mounting bolts. IMG_5140
Ford F-150 Lightning Needed: torque values for the Lightning ER front and rear shock mounting bolts. IMG_5139
COrocket
F-150
Is the 1x1 tube in reference to wedging it forward of the shock to try and get the holes to line up? I'm stuck at that step where when you jack up the shock, it slides forward since the shock is angled towards the front of the truck. Any tips from people who have done this DIY is appreciated
Ford F-150 Lightning Needed: torque values for the Lightning ER front and rear shock mounting bolts. IMG_3819
Itaintfastenough
Woody
Grandview Texas
HVAC Contractor
Yes, use a 1X1 metal square tube… about 6” long between the rear swing arm lower shock mount and the shock mount boss… do not use wood or any other material as it will bind up and not allow the shock to slide into position
COrocket
F-150
Gotcha…I got a piece of scrap 80/20 1x1 in front of it and it’s nearly perfect. I guess I’ll just have to use a Mallet to release the tube when I get the bolt in since it seems pretty well wedged in there
Ford F-150 Lightning Needed: torque values for the Lightning ER front and rear shock mounting bolts. IMG_3822
21st Century Truck
21st Century Truck
Martin
I used a transmission support screwjack here, to good effect. Its two ears held the bottom of the shock in position.
