- First Name
- CHRIS
- Dec 16, 2022
- alexandria virginia
- 2023 LIGHTNING PRO, 2012 Nissan Leaf, 2015 Toyota Prius, 2000 HD 883 Sportster
- Occupation
- Patent Atty / Electrical Engineer
Ford doesn't mention that cell balancing method anywhere for the Lightnings which have NCM batteries, that I am aware of, but that's not saying it is not a good idea or that it is a bad idea.They always show unrealistic range when charged to 100% and then it drops quickly as you drive. My Platinum ER is only rated at 300 miles but I’ve seen it show 320 after one of the battery updates in early 2023. It seems to forget your driving habits when it’s at 100% and show optimistic ratings.
also, it’s good to charge to 100% twice a year or so and leave it plugged in for several hours after it gets to 100% so it can fully balance all the cells, then go and drive it some to at least get it down to 90%.
if you never charge to 100% then you can end up with out of balance cells which can become battery warnings and shutdowns if the cells get too far out of balance
They seem to be using passive balancing which happens during charging, but we don't know much more than that, at least I haven't seen anything more.
Ford does recommend that for LFP battery vehicles, but not NCM battery vehicles, so I wonder if just going to 90% per their recommendation is enough?
Charging Recommendations
Ford has different recommendations to help maintain your vehicle depending on where you are charging it. Choose one of the options below to learn more.
Home Charging Recommendations (Level 1 & 2 AC Charging)
- Lithium Iron Phosphate (LFP) batteries
- Set the maximum charge level to 100%.
- Charge to 100% at least once per month to maintain estimated in-vehicle range accuracy for state of charge and distance to empty.
Important: If not charged to 100% at least once per month, you may experience degraded vehicle performance and a decrease in the accuracy of the vehicle's estimated range.
- Nickel Cobalt Manganese (NCM) batteries
- Set the maximum charge level to 90% to reduce strain on the battery.
- Set the maximum charge level to 100% to provide a full range for long trips.
My Nissan Leaf also uses passive balancing and there have been many forum posts about charging slowly to 100% and leaving it plugged in for about a hour afterwards to allow time for the cell balancing to do its thing.
Some swear by it, but others say it is not any more effective than not doing that.
I wonder if anyone has anyone done what you suggest in the Lightning and looked at the cell balance before and afterwards to see how well it worked?
My truck is a little over 2 years old and I have only charged to 100% once - by accident recently when an update eliminated my 80% limit and charge locations - and I have not received any warnings or shut-downs or other problems. I always charge to 80%.
I haven't looked at the state of balance of the cells, so I can't say what it is one way or the other.
If I got a warning or shut down I think my first assumption would be a bad battery module causing an imbalance the BMS cannot correct, and head straight to Ford for a check.
Bad modules have been an issue, after all.
