Dometic CCF-T install
Frode Vike
Frode
Norway
2024 Ford F-150 Lightning Platinum, 1969 Ford Mustang, 1989 Mercedes-Benz 300SE
I was lucky enough to get the very last CCF-T console fridge they had at Summit Racing earlier this winter. I just haven't installed it until tonight.
Ford F-150 Lightning Dometic CCF-T install 55199699464_a1a1d8a038_k
First thing was removing the top 7mm screw in the console cupholder, then popping the rear facia off.
Ford F-150 Lightning Dometic CCF-T install 55199699454_3840fd89ae_k
The next step was removing the 12v power connector. This is why I HATE wrenching on new cars. I spent more than 45 minutes trying to get this POS off, and busted it in the process. Looked up a YouTube video where the guy just pops it off with his fingers like it was nothing! Had me steaming. Every time I wrench on some new car, 2/3 of the time is spent fiddeling with these POS connectors. FFS! /Rant
Ford F-150 Lightning Dometic CCF-T install 55199450676_3e2e14483a_k
I drilled the hole for the power cord with a step bit instead of a hole saw drill bit.
Ford F-150 Lightning Dometic CCF-T install 55199699474_a95e25174b_k
The hole for the fan I did use a hole saw drill bit.
Ford F-150 Lightning Dometic CCF-T install 55199699499_e88a973d91_k
And then installed the fan.
Ford F-150 Lightning Dometic CCF-T install 55199699484_b0ab075f0e_k
Installed the power cord to the rear console. Also the rubber inserts below the lid was installed.
Ford F-150 Lightning Dometic CCF-T install 55199713909_f41c9b14c0_k
The bottom of the console lid had to come off to make room for the fridge to be installed.
Ford F-150 Lightning Dometic CCF-T install 55199713914_8f7196a30b_k
Then it the fridge was dropped in and snug down with the clamp screws.
Ford F-150 Lightning Dometic CCF-T install 55198624707_b9759018e0_k
The rear wires was not done messing with me. There was no way the 12v power was gonna reach the fridge contact. So I had to cut open the tape to make it reach.
Ford F-150 Lightning Dometic CCF-T install 55199615443_3b1ba98c51_k
Luckily I had a roll of that tape type.
Ford F-150 Lightning Dometic CCF-T install 55199450666_7c497778b8_k
Got it all tape up and plugged in.
Ford F-150 Lightning Dometic CCF-T install 55199713929_ba2f9bceb2_k
All done!
Ford F-150 Lightning Dometic CCF-T install 55198559842_aa28bbb4cd_k
Also, I found these plastic pieces inside the air ducts for the rear console vents. Got them out. Something to look for if you're ever back there.
Ford F-150 Lightning Dometic CCF-T install 55199855945_49eac24ff2_k
This is where the plastic pieces were. There was some in the other vent too, but I didn't get all of it out.
DavidS
DAVID
Green Bay, WI
F150 Lightning Lariat
Anyone else notice how cool the center console storage is normally in the summer when the rear AC is on?
TechnoSwiss
2024 Ford F-150 Lightning Lariat Carbonized Gray Metalic
Electrical Engineer
So is your rear 12v adapter un-powered now?
TechnoSwiss
Electrical Engineer
Yes it is. I have the same fridge.
I realize for the fridge this is probably best so that you don't overload that circuit, but if I was just looking to put a 12v plug in the center console and wanted both to remain live, since I wouldn't use both at the same time, and body know if there's a y-adapter you could tap in here?
Frode Vike
Frode Vike
Frode
Norway
I got to use the fridge on an all-day trip yesterday, and it was golden! A cool coke any time I wanted it, and it was really cold. Really happy with the upgrade.
bluey2025
Shane
Cape Coral FL
2025 Antimatter Blue XLT
Fleet Manager
Where did you get this thing from? All the sites I look at show as sold out for stock.
Frode Vike
Frode Vike
Frode
Norway
I got the last one they had at Summit Racing.
bluey2025
Shane
Cape Coral FL
Fleet Manager
Very lucky right there. It's got me contemplating how to do a 18 to 20 console swap as there are other vendors that still make a unit for that generation of F150.
Frode Vike
Frode Vike
Frode
Norway
Really ? Haven't seen those in a while either. Anyway, those consoles (and fridges) are quite a bit larger then the current style. Or at least taller because of the fold down work plate.
EvEddy
F150 Ligthning
Is this the updated fridge? I have the CCF-T but it says it's for up to 2020 f150.
Frode Vike
Frode Vike
Frode
Norway
Yes, this is for the 14th gen F-150s.
