Pedaldude
Even in the Raptor and on the Limited trim, it's an option....Is that standard these days for the new F150s?
I don't know if it's because Ford is greedy, or if it's to eke out that last tiny percentage of MPG for CAFE numbers.
I do know that even if it's not factory ordered, pretty much every truck will get it as a dealer add-on unless it's a work truck.
I work with a lot of plate steel and sheet metal, so I hate bedliners, even my last truck with the hard plastic tray would catch the edge of a sheet and get stuck. The spray in ones are even worse, when you're tugging on a 100lb piece of metal with a razor sharp edge and the static friction gives way to sliding friction, it's not desirable.
Still, I'm surprised that it's not standard to include bedliner in the higher trims like Platinum and Limited.
