COrocket
F-150
I couldn't find if anyone has done this yet, so I hooked up a Klein USB meter to each of my 2023 Lariat USB plugs and here are the results:
Plugs right below the main touchscreen:
USB-C: 15W (5V/3A)
USB-A: 7.5W (5V/1.5A)
Plugs within the center console:
USB-C: 15W (5V/3A)
USB-A: 5W (5V/1A)
Plugs for rear passengers:
USB-C: 15W (5V/3A)
USB-A: 5W (5V/1A)
Plugs in frunk:
USB-C: 15W (5V/3A)
USB-A: 5W (5V/1A)
So the USB-C is definitely faster, but unfortunately the plugs do not support power delivery with higher voltages. I used a newer iPad at a low SoC for testing, and verified that it is capable of requesting over 20 watts @ 15V to ensure I was maxing out the output. I didn't have the capability to test whether the outlets share any power, so I'm not sure if you could pull a full 4A with two devices plugged in.
Ford F-150 Lightning USB plugs power levels tested IMG_1752
CRAIGC540
Craig
Moreno valley
Technician
Thanks for the info.. Noted
IdeaOfTheDayCom
Joe
Staten Island, NY
IdeaOfTheDay.Com
Software Developer
USB-C: 15W (5V/3A)
USB-C: 15W (5V/3A)
USB-A: 5W (5V/1A)
USB-C: 15W (5V/3A)
USB-A: 5W (5V/1A)
Plugs in frunk:
USB-C: 15W (5V/3A)
USB-A: 5W (5V/1A)
Well done. I was thinking of testing them with my gear, but it's not as comprehensive as the Klein. Mine can only measure how much a device pulls, not the max the outlet can push.
viennaxmas
Sarah
Vienna, VA
It is another one of these items I would have expected different from a luxury car... USB-A should have at least been able to do 2.1 A. I also expected more from a USB-C.
Webbo85
Marc
Glenmoore, PA
Mech Engineer
Good thing you have a 120V outlet next to each one of those USB's if you actually need some decent power!
Thanks for posting this though, good to know.
Iroc34a
Roc
23 Lightning Platinum
Mechanic for American Airlines. GSE (ground equipment) 38 years. Worked on everything from Lawn mowers to Boeing 747's.
Is the USB C the only one for data transfer, such as phone used for Android Auto or Spotify, USB A is charge only? Jeez, just saw how old this post is !
K6CCC
Glendora, Calif.
The USB-A and USB-C on the dash (under the screen) are data. The rest are power only.
chriserx
Louisiana
Has anyone tested newer models? I ask because the truck seems to charge my macbook at a decent rate, but I haven't done any true testing with it.
