Stage3Motorsports
In stock and Ready to ship, message me for forum pricing.
2004-2022 F150 ICON Alpha 17x8.5" Wheel (Titanium) IVD1217856350TT
Unique, Aggressive Design Optimized for Off-Road Performance
Who says you can't balance form and function with your 2004-2022 F150 or Raptor's wheels? ICON's Alpha series 17x8.5" wheel is uniquely designed to allow for unhindered suspension travel and steering function. This rugged wheel's dimensions have been strategically designed to minimize scrub radius and improve handling and ride quality. If you're looking to make a splash off the pavement and show off on the streets, you can't go wrong with the Alpha 17x8.5" wheel by ICON.
Aluminum Alloy Construction and Titanium Finish
This ICON Alpha Wheel measures 17x8.5" with 5" backspacing and a 6mm offset. The wheel features a standard 6x135mm bolt pattern that fits your F150's hub without modifications or wobble bolts. Constructed with lightweight, durable aluminum alloy, the Alpha by ICON is built to get you through the toughest trails without adding a ton of excess weight.
Fitment: 2004-2022 F150 w/ 6x135mm Bolt Pattern
Wheel Specs:
Wheel Specs:
- Size: 17x8.5"
- Finish: Titanium
- Bolt Pattern: 6x135mm
- Backspacing: 5"
- Offset: 6mm
- Hub Bore: 87.1mm
- Load Rating: 2500 lbs.
