Stage3Motorsports
In stock Fifteen52 wheels are now on sale BUY 3 get 1 FREE!!!
The Fifteen52 Turbomac HD wheel is in stock in Block Bronze, Asphalt Black, and Magnesium Grey.
(magnesium grey is not on the site so you will need to message me to purchase)
2004-2021 F150 & Raptor 17x8.5" fifteen52 Turbomac HD Asphalt Black Wheel 0mm Offset THDAB-178565-00
2004-2021 F150 17x8.5" fifteen52 Turbomac HD Block Bronze Wheel 0mm Offset THDBB-178565-00
Highlights:
The fifteen52 Turbomac HD Wheel is one of the most unique and aggressive light truck wheels on the market, and makes for an awesome upgrade to your 2004-2021 F150 or Raptor. Designed with input from the legendary Ken Block and tested out on Ken's own Ford Raptor, the fifteen52 Turbomac HD is strong enough to survive even the most extreme applications while making your F150 or Raptor look like one of the toughest trucks on the road. The Turbomac HD features a unique dual-spoke pattern design that's combined with an aggressively-sculpted lip with stainless steel studs that set it apart from basically every other F150 wheel on the market today.Cast Aluminum Construction with Hubcentric Design and Aggressive Offset
Each Turbomac HD is built extremely tough and will survive whatever application you have in mind for your F150 or Raptor build. The Turbomac HD is made out of monoblock cast aluminum that's then expertly machined into the wheel's final look. This version of the Turbomac comes in fifteen52's Block Bronze finish with a black simulated beadlock ring that is sure to turn heads both on and off-road. The wheel features a standard 6x135mm bolt pattern and a stock 87.1mm hub bore, which makes it a fully hubcentric wheel. The 17x.8.5" Turbomac HD features a 0mm offset and 4.75" of backspace which pushes it farther than stock to help you clear wide wheels and add an aggressive stance to your F150.
Wheel Specs:
Fitment: 2004-2021 Ford F150
Highlights:
- Awesome off-road styling
- Influenced by Ken Block
- ****** finish with studded, black lip
- 0mm offset and 4.75" backspace
- Cast aluminum construction
Wheel Specs:
- Size: 17x8.5"
- Offset: 0mm
- Backspace: 4.75"
- Hub Bore: 87.1mm
