Stage3Motorsports
In stock and ready to ship for anyone looking to change their trucks appearance.
2015-2022 F150 FactionFab 6x135mm 1.50" Forged Aluminum Wheel Spacers (Set of Four) FFA1.10218.1X2
F150 Wheel Spacer Set Highlights:
Whether you're hankering to clear wide tires on high-offset wheels with awesome suspension upgrades or just want a wider stance for your F150, the FactionFab 1.50" Billet Aluminum Wheel Spacers are to help. This set of four high-quality wheel spacers allow you to give your 2015-2022 F150 the perfect stance and the clearance you need to run the wheels, tires, and suspension you've been craving all in a high-quality package that won't let you do both on and off the road. Both of the spacers in this kit are made out of high-strength forged aluminum that's flawlessly machined for a perfect fit on your F150. The spacers come standard with strong, steel studs, flanges for hub and wheel bore, and tapered lug nuts to provide excellent force distribution. FactionFab's Spacers are right at home for both street driving and aggressive off-roading in nearly any application you have in mind.
Forged Aluminum Spacers with a Black Anodized Finish and 12.9 Steel Studs
FactionFab builds each of these spacers incredibly strong so that your F150 can go anywhere and do just about anything without fear. Each wheel spacer is manufactured out of forged 6061-T6 aluminum that's then machined down for your F150's bolt pattern and hub bore to maintain the high yield-to-strength ratio of the aluminum. The spacers are then fitted with grade 12.9 studs with an OEM 14x1.5" thread pitch and a corrosion-resistant Geomet coating that keeps the studs in excellent shape in nearly any climate or application. The spacers come standard with grade 8.8 open-end lug nuts that likewise have a Geomet coating. The lugs have a tapered seat that works with the chamfered holes in the spacers to make installation easy and provide near-OEM force distribution. The spacers are topped off with a black hard-anodized finish with laser-etched lettering that gives them a great look and further protection from corrosion.
Set of four Spacers: this part number is for a set of four spacers. A version of this kit with just two spacers is also available.
May not be legal for street use: these spacers may not be street legal in some states (namely Pennsylvania and Massachusetts). Please check your local laws before ordering.
2021-2022 F150 Stud Trimming: the 2021-2022 F150s have slightly longer studs than the 2015-2020 models, and you may require stud trimming depending on your wheel option.
- Extremely strong, high quality wheel spacers
- Forged aluminum construction
- High-grade steel studs and lug nuts
- Black hard-anodized finish
- Designed for stock hubs and hub bore wheels
- Set of four 1.50" spacers
