2021 FX4 SPECS WANTED
HDT05
2021 F150 Lariat FX4 5.0
Hi
I have a 2021 FX4 V8 Lariat with Tow package and 21" chrome wheels. I love the truck and enjoy the drive. It's not too firm on the Texas roads and bumps in the concrete roads don't rattle the teeth,
BUT.......
It rolls like a pig....
I've noticed that on the tollway (if you're in Dallas you know the curves) the understeer is so bad that I'm bracing my left knee against the door as I hit a bend and then I just kind of aim and hope... (if there is ever a wreck then I know I'm STOL as I expect I will be spinning past....)
Can anyone point me to actual specs of the suspension so that I can look into sway bars and do something about the handling (not the ride)?
Thanks
Snakebitten
Coastal Texas
2021 F150 Powerboost Platinum
A rear Helwig sway bar will transform the truck. Obviously it's not a good idea off road if you need high clearance, but it puts some go-kart into the body dynamics.
Not an easy product to find in inventory though.
dhrandy
Randy
Concord, NC
1950 Plymouth, 2021 F-150 Lariat 500a
Engineering Tech
Hi
BUT.......
Thanks
Just an FYI, your truck will auto slow you down if you are going to fast around a curve with a feature called curve control.
