2023 Lightning Lariat towing capacity
Nwil10
Nick
2025 F150 Lightning Flash
Unless I’m not seeing it somewhere, my 2023 Lariat max tow does not seem to have hill decent control. Note that you also can’t use one pedal in off road mode. So maybe the solution when going down a steep off road decline is to switch to normal mode and then use one pedal to slow your roll. I hardly ever drive off road though so I’m far from an expert here.
You would know that you have hill descent control as you can toggle it on/off. It's not just an off road function.
You just don't want your brakes to go out (overheat) or pick up too much speed going down a long, steep hill while towing. Regenerative braking has a similar effect. One more (very small) win for the lightning.
