jbirdzee
Hi All - on my 23 Pro I did a swap of my ACM so that I could get HD Radio AND have the digital audio (A2B) port that is used on the B&O system.
No issues getting HD radio working properly, and for the A2B - I customized the harness that comes with the PAC AP4-FD31 adapter so I can get HSCAN3, Power, and the clipping connections at the ACM to the PAC module since I do not have the factory amplifier wiring behind the rear seat. The end goal was to get an all digital audio path (replacement ACM->PAC AP4-FD31->Optical to aftermarket amp.
I can get the A2B audio working, the AP4-FD31 is working, my amp with optical audio is working.
The issue: when I adjust the volume of the radio, the 12" display gives a popup of the volume control but it does not update. I think I have narrowed this down to the A2B slave setting:
On my stock config the XX value is "00" but the ACM only seems to push out A2B data if this is set to "03". When it's set to "03", I get sound, I get volume adjust, but the screen doesn't update (I get a volume popup on the 12" screen but it just stays at the last number). When I set this back to "00" the volume popup updates properly but I get no sound. Kind of a crummy tradeoff. Any ideas?
I was thinking maybe I could leverage the changes that would be made if someone was downgrading from the 15" to the 12" display as they would have the B&O config and the smaller screen, but I haven't seen anyone go through that.
