AlphaRex LUXX Headlights
AnthemMike
Michael
Alabama
2021 F150
Finally some pictures of the LUXX headlights mounted on a truck. These have the light activation feature when unlocking.
Pro model does not have activation feature and the NOVAs haven't been released yet. I placed my order last night for the LUXX and they'll be here this Friday.
Ford F-150 Lightning AlphaRex LUXX Headlights Screenshot_20220221-135635_Instagram
Ford F-150 Lightning AlphaRex LUXX Headlights Screenshot_20220221-151602_Instagram
Ford F-150 Lightning AlphaRex LUXX Headlights Screenshot_20220221-135639_Instagram
AnthemMike
Michael
Alabama
2021 F150
I plan to this evening. I'm actually fixn to install the DRL Harness. I read the website wrong and the outlined DRL won't stay on when driving in daylight hours (with auto function). Says I need that installed so I'm going to tap it into the fuse box here shortly.
AnthemMike
Michael
Alabama
2021 F150
Cutoff line..sitting about 25' back off the wall. When driving they seem just a tad low so I'm going to raise them a little. If I start to get flashed by other drivers I'll bring them back down a bit.
Cutoff line
Ford F-150 Lightning AlphaRex LUXX Headlights 20220226_210837
Lows w/ fogs
Ford F-150 Lightning AlphaRex LUXX Headlights 20220226_204643
Lows/Highs no fogs
Ford F-150 Lightning AlphaRex LUXX Headlights 20220226_204638
No turn signal light assistant (driver side)
Ford F-150 Lightning AlphaRex LUXX Headlights 20220226_204702
Turn signal light assistant (driver side)
Ford F-150 Lightning AlphaRex LUXX Headlights 20220226_204709
Turn signal assistant (passenger side)
Ford F-150 Lightning AlphaRex LUXX Headlights 20220226_204732
AnthemMike
Michael
Alabama
2021 F150
Had some issues wiring up the DRL Harness. They still work plug and play. But the DRL Harness will make the DRL outer light strip brighter and stay on while driving during daylight. Without the harness the outer DRL goes off when light switch is in "auto" mode. I tried tapping into #'s 124/100/80 in the fuse box under hood with no luck. Will be contacting Alpharex tomorrow for more insight.
Fords fuse box is so small using a fuse tap is kind of tough in some spots and not giving us a physical owners manual was a royal pain in the rear end while trying to use the app w/ owners manual to see the fuse # locations and description. Ford needs to put the fuse descriptions/chart under the lid like RAM does or give us a physical owners manual. Was highly annoying last night. Pinch every penny and charge more money.
I'll keep everyone posted on fuse location once I hear from Alpharex tomorrow.
AnthemMike
Michael
Alabama
2021 F150
Attached is a photo for anyone looking which fuse to tap into #21. Going to install the DRL harness now and will let you know outcome.
Ford F-150 Lightning AlphaRex LUXX Headlights Screenshot_20220228-114505_Driv
AnthemMike
Michael
Alabama
2021 F150
Haha no worries man!
Honestly, they feel really well built. The DRL Harness is just a standard harness (I feel it could be a little beefier but that's how all the companies do it these days). They're a MAJOR improvement over the halogen housings. I had LED Bulbs in the halogen housings and they were still garbage. So the lights are completely plug and play. But in the "auto" settings for lights in the daytime hours the DRL outline will nonstandard on unless you wire the DRL Harness which is supplied. Installing it right now. The DRL Harness will also make the DRL lights brighter according to Alpharex. Pretty simple (positive/negative battery post, connect to lights directly, and put a fuse tap in slot #21 on fuse panel underneath hood).
I ordered these....
Ford F-150 Lightning AlphaRex LUXX Headlights Screenshot_20220228-125145_DuckDuckGo
AnthemMike
Michael
Alabama
2021 F150
Okay so the DRL Harness is in and the fuse tap was put into #21 and good to go. The DRLs now stay on with low beams when the light switch is in "Auto" during day light hours. Once sunset hits the DRLs, low beams and fogs will be on. The DRLs are noticeably brighter with the harness. Light activation feature when unlocking works and all functions of the lights.
Fuse box with fuse tap into #21
Ford F-150 Lightning AlphaRex LUXX Headlights 20220228_141208
DRL Harness attached to inside of frame (put velcro on backside and threw two long zip ties around it)
Ford F-150 Lightning AlphaRex LUXX Headlights 20220228_141230
Snaked wire harness through little hole by my fingers and zip tied along another wiring harness.
Ford F-150 Lightning AlphaRex LUXX Headlights 20220228_141257
Snaked through frame on driver side and plugged in good to go.
Ford F-150 Lightning AlphaRex LUXX Headlights 20220228_141307
Final Product
Ford F-150 Lightning AlphaRex LUXX Headlights 20220228_144247
So far I'm extremely happy with these lights gives the truck a better look from those nasty halogens.
Any questions just let me know. Pretty straight forward once Alpharex told me which fuse to tap.
