jasonator
So after reading a few of us have installed the Amp Power steps with minor modification, I decided to pull the trigger.
I received them and got the truck modified to accept them and ran all the wires.
And that is where I’m stuck. They won’t operate. I have isolated it to the OBD2 port. When I ground the purple wires, it works fine.
Amp won’t help me. Won’t cross reference anything and pretty much said tough luck.
If you have the steps, can you tell me the number on the dongle itself that you have. Not the steps kit part number, but the dongle itself.
Update: Skyak helped me figure out what I did wrong. There are 2 wires that need to be tapped into under the dash. One is a white with green line. That’s easy to find. The other is a green with blue line. That I mistook as solid green and tapped into green with a purple line. That was my mistake.
I have them up and running and HUGE thank you to Skyak.
Thank you!
Thank you!
