Calibrating compass for the 21
Taco40
ND
CA
F150
2021 STX with about 200 miles on it, trans temp gauge stopped working at about 120 miles. Turing on and off the truck doesn't help.
Zyvin
SC
2021 F150 Crew, FX4, Lariat
For those with Compass problems, has anyone tried to reset the sync module? After that, I would look for a loose connection between the GPS antenna and the APIM.
gaffshot747
Ariel
Delray Beach, Florida
2021 F-150 STX 4X4
Anyone here with compass issues also having issues with the trans sensor not reading correctly?
Ditto...compass and Tran temp works when they feel like it.
Had a recent automatic update and both worked for a couple of days and I thought it was resolved but it wasn’t.
Missmy3/4ton
Midwest
300a XLT 5.0 4x4
I tired that a few hundred miles ago...Didn't work for me. I believe its a software issue. There's far too many people with issues with BOTH the compass and trans sensor for it to not be one, IMO. Or maybe they're some how related on a module or something?
Here's how to reset SYNC incase anyone else wants to try it.
  1. Settings tab on the center touchscreen.
  2. Select General Settings.
  3. Scroll down and select Reset.
  4. Touch Master Reset button.
  5. Follow the prompts on the screen to complete the reset.
Zyvin
SC
Yea, it’s starting to sound more like an IPC problem. I haven’t looked on forscan to see if that is a module that can be reset.
Monesti
Wisconsin
2021 f150 stx
Transportation
I had the same problem with my 2021 compass would show north on the 8 inch display and west on dash found an empty parking lot and did 3 slow circles and drove home when I started my truck the compass works
[/QUO
Is just everyone waiting for a 'fix'?
Or has anyone except Monesti actually tried a calibration technique?
compass stopped working wife took it to dealer they couldn’t fix it
nossiron
Ohio, USA
2021 F150 XL, 2020 Explorer XLT
I've scoped this site for a while, primarily for my 2013 F150 STX I just traded in for my 2021 but I literally created an account so I could post on this thread in response to others suggestions and
Monesti's post about running some circles in a parking lot. I have had my 2021 F150 XL for a few months and this week I had it in the dealer to have my seat cushion replaced (felt nick picky about it but the new one was totally worth it) and they said they had to disable some airbags to install it. The reason I mention that is that I am not sure if they had to disconnect the battery in the process but I noticed on my way home that the compass was not working after. I did not notice this behavior before since owning the truck, so I'm not 100% sure the replacement was the cause or not. However, after reading through this thread, and dealing with a stuck (dash always says S and Sync screen always says N) compass for a couple days I figured the parking lot circles were worth a try. On my way home yesterday I stopped in an empty parking lot, did 4 (i think others suggest 3 but i was trying to be thorough) counter-clockwise, slow circles. Parked and shut the truck off (opening the door to get everything to shut down). Started it back up, compass still stuck. I did 4 more circles, slowly, clockwise and shut it off again. Started truck up, issue remained. I figured, oh well, I'll deal with this another day. Got up this morning and started the truck and the compass worked right away, both on the dash and the sync screen. Obviously others have said theirs have been intermittent so I will post an update in the future, especially if it stops again. I hope that helps someone!
TL;DR - 4 slow circles counter-clockwise, shut truck off. 4 more circles clockwise, shut truck off. Drove home and left overnight. Started truck in morning, compass fixed.
nossiron
Ohio, USA
Is it still fixed?
Nope, I was just going to post, took it out earlier today, was not working. If it continues I plan to try the calibration thing again later this week just to gather some info. My transmission temp gauge seems to be working, never noticed it wasn't. Not sure how important that is, just that some others posted about the two being related.
nossiron
Ohio, USA
Follow up, was not working yesterday morning again on a short trip. Took another trip yesterday afternoon and it was working again, and also working this morning...
Agashi25
Arban
Chicago
2015 Mustang GT PP CO
Does anyone know how to calibrate the compass on a 2021 F1 50 with an 8 inch screen? apparently since I've had mine for four days I've been going north the entire time and I cannot find any settings to calibrate it
Hopefully it’s not like my drone.
Have to flip it upside down a few times and do figure 8s ?
nossiron
Ohio, USA
Mine continues to go in and out. It will work for a couple days then stop for a couple days then work again. I am not having any other issues, so I plan to bring it up to the dealer at the first oil change but I'm probably a couple months away from that.
andrewh521
Drew
California...
21 Leadfoot STX 4x4
Has anyone had the compass permanently fixed at a dealership?
I took my 21 STX to the dealer for the same issues. They had my truck for over 3 weeks and replaced the gauge cluster. Still has the same issues.
Monesti
Wisconsin
2021 f150 stx
Transportation
2021 Ford F-150 Styx the compass would work when it wanted took to dealer waited 10 days for parts the dealer replaced the module and works good now
satchamo
Indiana
2021 STX
My transmission temp gauge and compass both do not work - has anyone come up with a concrete fix for this yet or are we waiting for a software update? Not a huge issue but on a brand new truck it should definitely work….
Spooge1
U.S.
F-150
Sync reset sorted my Compass issue. Keep in mind you will have to reconnect your Ford Pass app, and pair your Bluetooth devices once again. There may be some other changes such as rear occupant warnings that you will need to turn off again as well.
As far as the trans temp gauge, those who daily drive short distances will hardly see this needle move. Long trips, under load, a few hard pulls in sport mode will get that needle off C. Give it a try. Good luck all.
