Charging Irregularities
brewski
GA
2023 F150L Platinum
Yes
My normal activity is to plug in every night.
Generally no problems.
Recently (in the last few months) when I make a longer run where my SOC is about 30% or less, when I plug in I'm getting what appears to be a handshake issue then a charging error.
If I unplug then replug I can definitely manually start a charge (which automatically goes to 100 ignoring my setting).
It is strange and only seems to happen at a lower SOC.
Thoughts?
Adventureboy
Are there any error codes on your EVSE? Charge errors are usually caused when you plug in, but the EVSE is not communicating with the truck successfully.
  • Try power cycling your EVSE first and see if the problem goes away.
  • Inspect your port and charge gun to make sure they are clean and debris-free. The small pins/sockets are the communication pins.
