Charging unattended
Adventureboy
Thank you for information. As soon as i get back to town ill reset the target charge to 85%……. Appreciate the help !
Rusty
If you have your FordPass account set up on your phone and you have your phone with you, you can do it anytime. You don't have to be at the truck to set up the charger parameters. The truck is connected all the time through WiFi or Cellular.
RustyMitchell
RustyMitchell
James
Anthem Arizona
F150 Lightning
Thanks. But I haven’t been able to find that on the app….
Adventureboy
Using FordPass isn’t necessary to set charging parameters. In fact, setting them in the truck is easier and more reliable.
Agree it used to be flakey but seems to work better now with the updates to the truck and app. I adjusted my change profiles through the app a few times for 2 different locations in the past 2 weeks and worked fine. 6 months ago it likely wouldn't have worked as well if at all.
Adventureboy
Press the Vehicle icon on the bottom of the app, then the Charging dropdown, then Preferred Times. Select the location and it will allow you to set the Max Charge Level for that location. Make sure to scroll down and press the "Save" button.
RustyMitchell
RustyMitchell
James
Anthem Arizona
F150 Lightning
Got it ! Done ! Thanks !
