DECKED Bed Storage Drawer Systems
Stage3Motorsports
Arizona
2021 F150 STX CrewCab 4x4
Available for 5.5 and 6.5ft beds
Message me for forum pricing.
Frank
2015-2021 F150 & Raptor 5.5ft Bed DECKED Bed Storage Drawer System DF4
2015-2021 F150 DECKED Truck Bed Sliding Storage System - (6.5ft Bed) DF5
2021 F150 PowerBoost 5.5ft Bed DECKED Bed Storage Drawer System (Pro Panel Access) DF8
2021 F150 PowerBoost 6.5ft Bed DECKED Bed Storage Drawer System (Pro Panel Access) DF9
Ford F-150 Lightning DECKED Bed Storage Drawer Systems 1632945987206
Highlights:
  • Heavy-duty, drop-in bed drawer system
  • Features two large-capacity drawers
  • Extremely strong construction
  • Can handle up to 2,000lbs of load
  • No-Drill Installation
  • Storage organization accessories also included
  • Optional accessories also available
  • Backed by a 3-year limited warranty
DECKED F150 Sliding Drawer System For Countless Truck Bed Storage Options
Organization and storage just got a whole lot easier to manage in the bed of your F150 with this Sliding Drawer System from DECKED. Designed to be a perfect fit for your bed size, each of the two sliding drawers pull out to provide countless storage and organization options. Each of the two drawers lock to provide a new level of safety and security and give you peace of mind when your truck is unattended. Manufactured in the U.S.A., with a 2000 pound deck load rating, each system is custom cut to fit the exact specifications of the bed of your full size pick-up truck without any drilling needed. It's built from 100% recycled high-density polyethylene which is co-molded to a steel sub frame and installs utilizing your truck bed's existing tie-downs. No drilling is required and your new tie-downs simply install on rails on the new deck of your truck bed. DECKED Locking Drawers Capable Of Holding Up To 200lbs. Each
Weatherproof and secure, both of the sliding drawers can be locked with a key to protect your valuable gear and keep guns safely protected from theft or the curiosity of children. The storage options are endless as each drawer rolls out smoothly on sealed bearing wheels and can hold up to 200 pounds, making them handy for anything from hauling heavy loads to and from the job site to providing a temporary storage solution for hauling back your catch from your fishing trip as well. The Sliding Storage System also makes for a perfect mobile work station since each drawer slides out to the desired location of your powerful and heavy tools in an easy to reach and use location so that you don't have to keep searching for tools out of your F150's bed. The flexibility of this universal truck bed solution makes it perfect for work, play or both. Each DECKED system also comes with a Desert Tan D-Box, a Desert Tan Cross-Box, a pair of drawer dividers, and a drawer organizer. All other accessories are available at additional cost.
Additional Features:
  • "Ammo Cans" on either side of the wheel wells act as (4) areas of additional storage.
  • Lids of "Ammo Cans" flip over to provide (8) cup holders or a handy place to store nuts, bolts, or screws when working on or near your truck.
  • Stainless steel edge guard ruler and bottle opener.
  • DECKED can handle UV light, moisture, and extreme heat or cold.
  • Installation hardware and detailed instructions are included and installs or can be removed in about 20 minutes.
  • Precise fit ensures no gaps between the deck and sidewalls of your truck bed.
Important F150 Fitment Notes:
  • Does NOT fit the F-150s with optional loading ramps and will block the truck's stock BoxLink Bed System.
  • Does NOT fit with a drop-in plastic bed liner or BedRug Kits, but WILL work with a spray-in bed liner.
  • Blocks the Pro Power Panel on PowerBoosts. A version that keeps the panel accessible is here.
3-Year Limited Warranty: DECKED is so confident in the durability and toughness of it's Sliding Storage System that they back their product with a 3-year Limited Warranty.
Some Accessories Sold Separately: this bed drawer system comes standard with a Desert Tan D-Box, a Desert Tan Cross-Box, a pair of drawer dividers, and a drawer organizer. Core-Trax rails, locks, and drain plugs are available at additional cost from our drop-down menu above.
Ford F-150 Lightning DECKED Bed Storage Drawer Systems Decked-bed-storage-system-features
Ford F-150 Lightning DECKED Bed Storage Drawer Systems 1632945961078
nearly
2021 F150 Lariat
Do you guys have any pictures for the 7.2 Kw power panel? I know it has the option for cutout but I'm wondering what that looks like.
Stage3Motorsports
Stage3Motorsports
Arizona
Not a great one, but in this pic you can notice the wires running in the lower corner, normally that area is blocked off, in this application the area is open to access the panel.
Ford F-150 Lightning DECKED Bed Storage Drawer Systems 1641939973327
