DTC Codes C0604 & C0630 - Active Air Dam Issues
LightningRob
Rob
F150 Lightning Flash
So today I decided to take a quick look and see if I had any active DTC codes on my 2024 Flash (nerding out in Forscan). I noticed 2 concerning codes (C0604&C0630) that triggered as recently as yesterday. Looks like I have an active air damn stuck and active air damn control circuit performance issue. I took a look at the active air damn and I can see it's in the open position sitting in my driveway, but nothing seems to be blocking it. Does anyone know of a fix? or is this a dealership visit? Thanks in advance -Rob
Ford F-150 Lightning DTC Codes C0604 & C0630 - Active Air Dam Issues IMG_2046
Ford F-150 Lightning DTC Codes C0604 & C0630 - Active Air Dam Issues IMG_2045
Frode Vike
Frode
Norway
2024 Ford F-150 Lightning Platinum, 1969 Ford Mustang, 1989 Mercedes-Benz 300SE
I have the same issue. Just found it now with Forscan. Also 2024 MY.
zkeith
keith
oregon
2022 lightning lariat antimatter blue SR
engineer
I had a 2006 ford escape hybrid, awesomely excellent vehicle, that had a similar issue. My '22 lightning gets this error as well. On the escape it was a mechanical door with sliding contacts that had lithium grease on them too keep down corrosion, but as the door closed the contacts slid along and could spark. This would trigger this error code sometimes. I replaced the device, the damn door, several times, but it always started tripping that error again and again in a couple of years. A mechanic told me it was just a bad design, I tend to agree.
Note on the escape it was a door that would open to let fresh air in to circulate around the battery pack. I have no idea where it is on the lightning, or if it's related. Just me rambling, attempting to feel relavent. I am not worried about it, unless it becomes accompanied by another error code.
Keith2230
Keith
2024 F150 Lightning Flash
My 2024 does this occasionally as well. I saw it happen twice. It will open and shut the damper about three times. It appears to fully open and close. Yet, it logs the error. I’ve been ignoring that code land will continue until I see the damper actually stuck in an odd place.
