Factory Wheels with Aftermarket Tire Thread
Torch
Christian
Bend, OR
2021 F-150
So after reading everyone’s information on tire size I decided on the Nitto Ridge Grapplers 35/12.5/18’s and I think it turned out great..
I agree. Looks great! What level did you go with?
JahWolf
Un
2022 F150 Lariat Powerboost Smoked Quartz
Has anyone ran the Kumho Road Venture AT51 tire? Looks to be a solid all around tire and good in snow but also towards the budget side of things.. I’m looking to get a 33 inch tire and possibly a 2 inch level either at the time of purchase of tires or later. That being said will the 275/70R18 work without a level or with or both? Appreciate any and all help!
Hartz
Vancouver, Canada
2021 F150 XLT
Oh man. Its been a while since I've hit these forums. All these trucks are looking dope, guys and gals. Love the factory wheels with new tires.
I have a 21 fx4 with the factory 20s and 285/65/20 ko2's without a level. Been rocking them for 10 months. As mentioned in a previous post, there is very minimal rubbing on my left front tire when I turn the wheel all the way right and it's only apparent when in reverse. Minor inconvenience and tbh I've just been too lazy to trim whatever is rubbing.
RapidRed5_0
New England
2016 SC F-150 XL Sport 4x4 5.0L - 2021 On Order
I know a member on here had them and he rubbed, maybe not on pavement but on articulation I'm sure it'll rub. Also Wild Willies Customs did a truck with that tire on a level and the owner left a comment on the video that it rubs at full lock. It was a 2wd though so on a 4wd it probably wont be bad but it depends if you're willing to have some rub vs none.
Here's the link to the video
Edit: The member on here that ran that size had aftermarket wheels with a more aggressive offset and the guy on the video had stock wheels but 2WD so actually I don’t think I’ve seen anyone rock that size on a 4wd truck with stock wheel yet.
Well after some further consideration, going with a 295/70/18 is probably a better option all around anyway. For one thing, you can get an SL tire which is considerably lighter than an LT. That will help with the hit of MPG loss from a level. Also, I have the 3.31 rear end. I wish ford offered the 3.55 for the 5.0L. In hindsight, I'm kinda kicking myself for not going with the 3.73. Oh well...
Thanks again for the help!
Tizzzo
Ed
2021 Lead Foot Gray XLT 5.0 Supercrew 4x4
Veteran
Yeah that's probably the safest route since multiple people are running that size without issue already, its going to look good!
Steyreo
Pacifica, California
‘21 Lariat SuperCrew PowerBoost Fx4
Can we get pictures?
JoeMo
St. Louis, MO
2021 f150 Powerboost lariat sport
I had my fox 2.0 leveling kit put in today with 295/60/20 ridge grapplers. The upper control arm is extremely close to the tire even in the neutral position. It rubs quite a bit at full lock. The dealer did lower the spring perch 5/8” like Rousch recommends for the 2021 MY. I also still have 1.5 inch of rake left. I have a 2021 F150 502a lariat power boost with the max tow package. Please help! Did the dealer do something wrong?
Ford F-150 Lightning Factory Wheels with Aftermarket Tire Thread 01DCB93F-5EC0-4EC4-9B83-3C493DB63327
Ford F-150 Lightning Factory Wheels with Aftermarket Tire Thread C7B67468-4CB6-464A-9EE2-3BCAC83A9132
Ford F-150 Lightning Factory Wheels with Aftermarket Tire Thread 31FC0E20-39A6-4D49-ADF2-219838470648
RapidRed5_0
New England
Man that sucks! I don't think the dealer did anything wrong other than maybe not being knowledgeble. I believe the power boost weighs almost 1k pounds more and the max tow has higher capacity springs in the back. It's possible that the fox 2.0 coilovers weren't meant for it. I also think Fox is still working on products for the 21+ F-150's. You may have go with a puck style level or check out Icon Vehicle Dynamics and see if they an offering for the PB. Good luck! Keep us posted?!
SuperClyde
2021 F-150 Lariat Sport 502A
I have the exact same truck was thinking about doing the same set up. Did you find much MPG change with it being a powerboost and the KO2 being alot heavier than the stocks?
Sorry for the late response. I haven't been on in a long time. It lost about 2-3 mpg depending on how I drive. With good weather and if I'm conscious about accelerating and braking I can easily get 20 mpg with it. Otherwise it's usually ~18.
Badhabit
Missouri
2018 F150 SCrew 4x4 5.0 302A
How much rake did you have before? A lot of these trucks have 3.5" of rake, so 1.5" is to be expected with these coilovers.
As far as the tire being close to the balljoint, get a set of 1/4" spacers for the front and you'll be good.
JoeMo
St. Louis, MO
Only spacers for the front? Will it look weird with the rear not having the same poke?
Badhabit
Missouri
It's only 1/4" per side. And the front track width is slightly less than the rear stock.
DGretka
MI
2010 RKP
285/75r17 toyo open country at3’s on xl steelies with 2 inch level
Ford F-150 Lightning Factory Wheels with Aftermarket Tire Thread A329AAE7-4BD5-4D35-BBB3-AA14216895D9
