Failed Upper Ball Joints
UWdave
2023 Ford Lightning Platinum
Spent some time yesterday removing previous owners lift and wheel spacers. While in there I noticed the upper ball joints were toast. I could just grab the knuckle and get 1/4” of slop. Both sides.
2023 with 27k miles.
ReadyLift front leveling spacers and 1.25” wheel spacers.
Probably mostly due to the wheel spacers, but the lift probably didn’t help.
WhiteBolt
Ed
CFL
Manufacturing
Moving tires/rims outboard of oem position puts additional load on suspension parts.
It would also be a good idea to check your wheel hub bearings for wear or looseness.
UWdave
Stock 22” with 305/45R22 Nitto MTs.
Spacers were just for looks as the tires don’t rub without them. Ordered stock size from Costco.
I decided to just order new upper arms rather than deal with the dealership. So much for “safety inspection”. $300 for new Mevotech Supreme arms. I figured they may say “wear item” and you could clearly tell I just had the suspension torn apart.
DatOleMan
Buzzz20!23
2023 Lightning Lariat and 2022 Mach e Premium
Did you check for a recall on your vehicle? I have a 23’ Lariat that had a recall on upper control arm ball joint.
