lipnorth
Connecticut
2023 Ford 150 Lightning Lariat
Unfortunately, I just think pick up truck drivers have a huge bias against EV’s that it is difficult to overcome. That in the lack of advertising and awareness only adds to the problem.
Look at this article where they drove a lightning in Texas and you can see the bias in action. And people were very ignorant about the existence of our features of the lightning.
https://apple.news/ArXFFhbivT2SgORwWTYJM1Q
Danface
Central Mass
2023 Lightning XLT
I am not in the business but my outsider impression is that it is easier said than done. I don't think it is just a matter of buying smarter developers (although that definitely would help). The problem is Lightening is Frankensteined by slapping together tons of modules from different manufacturers. In order to get this Sh. Show under control, Ford either has to buy Rivian/VW brain and build a car around it or build a brain and body from ground up which is a completely different business model than mostly assembling what you get from your suppliers (including software). I am not saying Ford should not do what you are suggesting. I am just saying it requires heavy investment and risk.
I don't think the two of you disagree on that. I think Rick is saying if someone does not want to deal with the tech, that is their loss. And you are saying it is the car company and environment's loss if we can't lower that friction. The fact is current situation is what it is, and it will inevitably improve.
In a supermarket, I am like a deer in a headlight. My wife is that way with the computer settings and DCFC charging. She does the food shopping and I do the charging. Both of us are smart enough to learn the other stuff but the amount of energy it takes to get comfortable in each area are different for each of us. Her smart phone is capable of much more than she uses it for but it is designed so what she needs the device for works seamlessly so she does not have to spend the time she rather put on her garden messing with the phone.
I used to have higher tolerance for spending time fixing stuff and making things work but As I get older and have less time, I am more conscious of how I spend it. Opportunity cost of having to deal with a badly designed system is something many refuse to pay. But we all know designing the perfect system on the first go almost never happens. So I stopped becoming an early adopter. Now I wait until a tech is mature enough for me to own. First gen Honda Insight intrigued me immensely but I waited for Lightning. I am glad I did. In the same way, that a lot of folks got into EVs long before me, there will be more that will get in them after.
I drove dumb vehicles for 45 years before I got the truck and and I don't see how adding an app and letting Ford know everything about me is an improvment. I didn't really used the app when I got the truck back in Jan 2024 and I didn't accept the new "Terms and Conditions" that popped up about 6 - 9 months ago when I downloaded the new app so I just get in and drive it and it works great.
Funny thing, the truck is shop for the sceen blackout recall and they've been struggling with the software upgrade for the last 5 days. The only thing I don't like is the loaner (Explorer) isn't and EV, I can't wait to get the truck back!
BTW, I let them know I didn't accept the "Terms and Conditions" just in case that's the "problem" :)
21st Century Truck
Martin
Just bought a used Mustang Mach-E (2021). You say you drove it into the ground. What specifically how many miles did you get out of it? What was its demise?
75,001 miles on the odo when I traded it for the Lightning.
Three (!!) front motors, all under warranty, but still... when the 2d motor started giving me warning signs and the shop techs told me it showed metal shavings in its Mercon coolant, I decided to make it the next guy's problem.
The replacement of these motors, all within 26 months, made me learn that, when a dealer replaces such a major component under warranty, that component is only warranted for the next 12 months, so based on that history I would have to keep blowing the front motors every 11 months or less (ha haa), or pay out of pocket for the next iteration at 12+ months following.
The fact that I had the KW coilovers on the car since it hit about 23 thousand miles might, or might not have had anything to do with these failures, due to some slight potential changes in the angle of the front half-shafts going into the front motor... but I wasn't about to discuss that with Ford.
Hope this helps...
lipnorth
Connecticut
Hope this helps...
Thanks for the info.
Interesting about the motors. The used one I bought has 70k miles. But my dealer insisted on selling me a bumper to bumper warranty (at a discount) since the car was for my kid. So the motors, battery and everything in-between is covered for three years or 100k miles. Usually i dont go for this things but something in my head said to buy it.
21st Century Truck
Martin
I suggest making one, very very easy and cheap, mod to Your family Mach E: change the rear window wiper blade which is a 12-inch long Escaoe wiper blade Ford reused, to a Bosch 16-inch long wiper blade. The extra 2 inches on the outer end make a huge difference at night in the rain, right on the top of the swept area where the distant headlights behind You will be. I think the Bosch wiper blade is called either the A410, or the 410A model.
lipnorth
Connecticut
Good tip. 2 inches makes a big difference. ”Thats what she said.”
Stephen
Westford Ma
2023 Ford lightning
Optician
I have to be contrary to this view.
You are an enthusiast, which also means there is a bit of a bias. Not saying that in a bad way.
The lightning does road trip, and its as comfortable as it always is. However the time spent to charge is annoying when trying to reach a destination. Dare I say that for the majority of us the journey is not the goal, the destination is. And in that the time spent charging is frustrating. Not impossible, but frustrating. Hauling two adults and two kids on a limited timescale to reach a vacation? Yeah, 35 minute stops every 2-2.5 hours gets old real fast. Trying to push 1000 miles in one day, a trip i happen to make regularly. That went from a long day to a murderous one. That used to be a 14hr drive, now its 19.5.
Not saying it cant be done, or that your mindset is wrong, just that your mindset is yours and not the same as others.
As for chargers, that IS still an issue. Its not impossible to plan the trip, I actually enjoy doing so. However you DO have to plan it. There is no "hey, look at that, let's throw the truck on a charger and check it out", if bio breaks come up its fuss with an app, not "let's stop there and get a charge". Stopping for ten minutes, just to stop 30 minutes later at your planned charge stop is frustrating. It IS possible to charge, and do so relatively easily, in most locations. It is not however as universal as getting gas, not by a long shot.
I completely disagree that in order to make cost competitive EVs they have to change their production process. They are a business, cutting cost IS THE big thing to do EVERYWHERE. There is no special cost cotting on a Lightning vs the regular F150, every penny spent making ANY vehicle is a penny that isnt profit regardless of what powers it. I want an EV that was made by the hundred years of lessons learned making gas cars, not something new.
I guess electric vehicles aren’t for you
Evans
Evans
F150 '23 Lightning Lariat
Look, you're not talking about "backroads", you're just not on the main interstate.
Take a roadtrip to eastern Oregon, or Northern Montana. Then come back and tell me there is no infrastructure problem.
I agree for the most part. Last summer I took the family 3,400 miles from Seattle to through Yellowstone to Jackson WY. It’s possible but not seamless. If ford pulls the pin on the lightning some else will fill the void. It’s not only a great truck it’s great machine. The economics and some other factors may have already cast the dice. My salute goes to the designers, the assemblers and yes the risk takers at ford for producing the lighting. Thank you.
