Jseis
- Jul 22, 2023
- Washington
- July 2021 SR MME, July 2023, Lightning Lariat
After stewing on Ford’s Extended Range Electrical Vehicle tilt I began to research hybrids and Formula 1 race cars in particular. Ford has signed a partnership with RedBull. The current RedBull F1 racer is extraordinary as are all current gen F1 race cars.
Imagine a 1.6 liter V6 spooling up to 16,000 rpm, generating 850 horsepower, nearly 500 ft lbs of torque, recovering 33 seconds of braking energy per lap as well eliminating heat energy from the turbo by switching to a high speed electrical motor driven turbo.. and running 16:1 compression. Total horsepower is around 1,000 of which 150 hp is generated as electricity. The next power system unit will produce ~400+ electrical hp with the balance by the ICE. That 1.6 liter ICE is in house a in-house design! And depending on the course the racer averages 6-7 miles per gallon! Insane. An ICE at 50% efficiency is even more insane (particularly 16:1 compression ratio).
The RedBull-Ford partnership now makes sense for power unit developers interested in the mashup of fuel-controlling turbo heat offset with electric motor spooled turbo-braking-battery-electric motor mashup. Quite a challenge in dealing with the deadly killer of ICE (heat) with seamless power generation through battery-motor power, braking regen, & etc.
Turbo heat control by spooling a turbo with an electric motor to 25,000 rpm. Crazy!
A towing 700 mile range truck powered by small V-6 w/serious power/torque. While I doubt it’ll ever see the 80 mpge… 40 mpge might be possible (empty) with energy recovery and 50% ICE efficiency (I’d guess that’s possible given the F1 engines are all ready there). The new F1 parameters are 40% electrical energy output so pretty steep challenges.
But Ford’s EREV push makes sense ‘cause more range and powah! The new tech battery density curve-slope probably not going up fast enough and we all know what heat means… dealer visits.. so they’ll be happy ‘cause I smell maintenance.
I also see F1 differently. Serious engineering. Mercedes figured out how to get to an 18:1 compression ratio & RedBull found out… attempting to mimic results. Puts F1 leadership in a quandary as that’s a Mercedes advantage if no other team has it. Intrigue!
Links:
ford f1 partnership red bull - Google Search
red bull f1 engine - Google Search
red bull f1 engine horsepower - Google Search
red bull f1 engine torque specs - Google Search
red bull f1 engine miles per gallon
Links:
