Newton
I agree that if you want any kind of decent performance the battery has to be available, but I'm not sure that is what happens.Because you dont have to run the battery to minimum SOC. Thats just computer logic to balance generstor output and battery output. Ultimately though the battery HAS to be available, the demand placed on the system is highly variable and the battery provides that variation.
No reason that at 50% SOC the generstor kicks on full time, and at 25% SOC speed and acceleratiin are limited. Or 75% and 50%. After that its just giving the drivers some settings to bias the system one way or another.
If we want to speculate about these systems we need to know the output of the generator in kW, and we don't know it for either of the two EREV truck systems that are in or close to production. You cannot know this from the HP rating of the gas engine, as I have said often.
So, consider this to be wild speculation based on some knowledge. I believe that the Ramcharger is a 30kW system based on some information and speculation. In one report, I read that they can send 30kW to a house in an emergency. The Pentastar V6 has a displacement of 3.7L which would be too small for a 50kW Diesel generator (4.5L for this 50kW) but about right for approximately a 30kW generator. I know that I am comparing different technologies but a diesel engine will always be capable of more torque than a similar displacement gasoline.
I also looked at the dimensions of the Ford Ecoboost V6 which I think is the largest engine that fits in the F-150 compared to the dimensions of the diesel generators and again, roughly 30kW is all that I think can fit. This is of course very speculative and rough but I'd say that 30kW is in the ballpark and even trying to get that much from a gasoline engine that is specifically designed to be light is ... bold.
If we use 30kW as a benchmark then we can go even further out on the speculative limb to see what the managers are thinking while the engineers cringe. The Lightning is rated at about 2.6 mi/kWh from the EPA (Lariat 320mi/131kWh). At that rate, one hour of driving will generate a (absolute maximum) of 78 miles of charge so if you keep it under 80 you can drive as much as you have gas in the tank + the electric range.
Unfortunately it is not that simple, beginning with the fact that I rarely see numbers that high and certainly not when towing. Additionally in the heavy towing cases that the EREV is supposed to solve, the battery will be hot which limits how much charging you can do.
The really hard problem to solve is that 30kW is not going to drive the electric motors very well, and while it is driving the motors it is not charging the battery. So once the battery is down it stays down until you fast charge. The assumption when they say things like "700 mile combined range" is that you can just go to a gas station and fill up - but that is not true. You will have to go to both a gas station and a charger for the next leg of your 1400 mile trip.
To make this work as a driver, I think you are going to have to be very aware of your current usage, expected usage, and plan on turning on the 'charger' much earlier than you think - probably at the beginning of your trip. For customers who already have difficulty with route planning ("just use ABRP!" we say so often) this is going to be even more off-putting.
The really big question for me is "how well does it drive with the battery completely empty?" Can I tow my (imaginary) big rig up Washington Pass, and at what speed?
