Glare free headlights NOT enabled on my Canadian truck
Rtashiro
Ryan
Winnipeg, MB, Canada
F150 lightning lariat, Mustang MachE
Hi. Everything I read online says my truck should have the glare free auto headlamps enabled on my truck. I am located in Canada and purchased brand new from a local dealer. There is no toggle available to enable it. Is this something I should take to the dealer or should I just enable it myself on forscan? I’m curious why my truck isn’t enabled. It’s a 2023 lariat
digitaldad
ABQ
2023 Lightning Lariat ER
My vote is just FORScan it if you're inclined...I'm sure thats much faster than trying to explain it to the dealer (then schedule/do the actual work).
Rtashiro
Rtashiro
Ryan
After posting in this I asked chat gpt and this is what I got
Why ā€œGlare-Free High Beamā€ / ā€œAdaptive Matrix Headlightsā€ Are Disabled in Canada
Even though your 2023 F-150 Lightning Lariat has matrix LED headlights, Ford software-locks the glare-free function in North America (U.S. & Canada).
1.
Regulatory reason (main cause)
  • Until February 2022, Transport Canada and NHTSA did not allow adaptive ā€œglare-freeā€ high beams — they required either full low beam or full high beam only.
  • Even though the U.S. and Canada have since approved adaptive driving beam (ADB) technology (it’s legal now), Ford hasn’t yet certified or activated it for the F-150 platform here.
  • Certification involves expensive testing, so Ford has chosen not to re-certify existing models just for software activation.
In other words:
The hardware is capable, but the software feature is turned off to comply with regional regulations and to avoid recertification costs.
2.
Regional software locks
  • Ford builds one global version of the headlamp control module, but regional software (North America vs Europe) sets the feature set.
  • The ā€œglare-freeā€ or ā€œmatrixā€ function is active on some European F-150 / Ranger / Lightning variants, where regulations have permitted it for years.
  • In your truck’s Body Control Module (BCM) and Headlamp Control Module (HCM), the ā€œglare-freeā€ parameters are set to Disabled or ā€œNorth American mode.ā€
Even if you enable those bits via FORScan, the feature won’t work fully unless:
  • You flash in the European HCM firmware (which is risky and could brick the module), and
  • The truck’s firmware supports the communication between BCM, IPMA (camera), and HCM in ADB mode.
So, it’s not just a toggle — it’s a combination of regulatory lockout and software-level firmware limitation.
3.
Ford’s public position
Ford has said (in F-150 forums and support responses):
ā€œThe F-150 is equipped with Matrix LED headlamps but the adaptive high-beam functionality is not enabled at this time in North America.ā€
The expectation is that Ford may activate it in a future model year (possibly via OTA update once officially approved), but as of the 2023 Lightning Lariat, it’s disabled.
Rtashiro
Rtashiro
Ryan
Perhaps my truck was just built before it was certified to work in Canada?
