Heated Steering Wheel Retrofit?
fayby
2021 F150 Lariat
I ordered a Lariat with front row bench seat and just realized it does not come with heated steering wheel. Granted it’s a first world problem I’d be very interested in getting it installed afterwards.
anyone in the same situation and have made any attempts?
tn.lariat
Nashville
2021 F150 Lariat Screw Powerboost 501a
retail
This is the only thing missing from my 501a build. From what i see is that it is a dedicated hard button now compared to one on screen which was done thru forscan and different steering wheel and clockspring pins change to get it added. Still waiting if someone else has found out the new method on newer 21's to change this or does it only require replacing controls on center consol for one with heated steering wheel button. Ford parts web site has them at $700 but not sure if a new steering wheel is needed as well as new clock springs. For now a pair of gloves will remedy this missing feature
wolfnards
Boston
F150
Yes, very interested here as well. I want a front bench seat but you can't order one with heated steering wheel nor the 501 high package. Would like to retrofit heated SW.
va
2021 F150 XLT (HDPP+MTTP)
Ditto - I needed heavy duty payload package which limited me to XLT 301A so couldn't get a heated steering wheel which SUCKS when you have really poor circulation in your hands and they feel freezing anytime the temp is below 70. If anyone knows how to do a swap with a raptor steering wheel in a 2021 please let me know!! Would gladly pay top dollar for a kit from Boosted Grey Goose!!
EatDirtFartDust
Josh
St Louis, MO
2021 Ford F-150 XLT, 2015 Lincoln MKZ
Ford service manager
You got Reynauds too?
Sucks in the winter time. I wish I had a heated steering wheel, but I couldn’t bring myself to spend the extra $5,500 it would have cost to get that, ventilated seats and a rear sliding window. As those were the only things I cared about stepping up to a Lariat.
EatDirtFartDust
Josh
St Louis, MO
It’s worth up to $600 and 4 hours of labor, in my book.
dhageremtp
D
Silva, ND, United States
2022 F150 Lariat
Healthcare
I ordered a 501a for the bench seat so I have room for 6. I plan to work to retrofit a heated wheel as soon as I can. Truck is set to be in Feb 20th. So far here is what I think:
heated wheel is part ml3z-3600-ra
clockspring (need verification it is for heat) ml3z-14a664-b
steering bolt W7210795437
will need replacement heat/AC control module to get heated wheel button, I do not have a part number here as I am unable to locate the part with heated wheel button
lastly not sure if a new sccm will be needed or not, I am hoping the lariat trim will have the correct sccm and that the heated wheel option can just be activated via forscan.
I am happy to discuss further. again not 100% certain on the above, just my start at research for the project.
Jesse-Infotainment
Jesse
2024 F150 Lightning Platinum
I am doing this already, If you have a lariat you may get away with the wheel and a SCCM with the heated circuit. The way to turn it on though is in the HVAC module so you may need a new one. Its about $500. You may be able to program the apim to turn it on and off. I cant say for sure. The heated wheel is actually control from the Driver seat module. Lariat and above have it already xl and XLT does not.
Since the wheel isnt wired to the HVAC control you may get away with having a soft button on the screen.
I ordered the SCCM its on back order until april.
There are two ways to order the SCCM.. as a complete assembly with the turn signal stalk and you can get just the airbag contact as they call it in 21. I order the entire assembly.
Jesse-Infotainment
Jesse
Mind sharing the part numbers you ordered? Will follow along to see how it goes....
Yeah I dont mind.. Ill have to find them. Im not exactly an organizational expert
dhageremtp
D
2022 F150 Lariat
Healthcare
Jesse-Infotainment
Jesse
ML3Z3F791BB
This is the Complete assembly with turn signal stalk
ML3Z14A664B
This is what they call the Airbag contact assembly
