Looking for Forscan BdyCM tire values for Lightning Lariat.
WhiteBolt
Ed
CFL
Manufacturing
I recently put a set of factory 20" Lariat rims w/General Grabber HTS 275-60-20 tires on my 22' Pro and my speedometer is now consistently reading 2mph slow.
I want to use Forscan to recalibrate the speedometer. I have already scanned my truck and saved backups of all "as built" modules. I know there are tire calculators out there than can give me tire circumference, but I would rather copy OEM BdyCM factory values directly from a Lightning Lariat. I think these would be the most accurate values to get my speedometer and GOM reading correctly.
Forscan values from my Pro w/18" rims:
BdyCM - Tire Circumference=2476
BdyCM (as built) - 726-12-01 = xxxx 3146 xxxx
726-15-01 = xxxx xxxx 09xx
726-15-02 = ACxx xxxx xxxx
Would appreciate if anyone could tell me the factory values from their Lightning Lariat.
Thanks
WhiteBolt
WhiteBolt
Ed
CFL
Manufacturing
I found the data I needed here..... https://www.motorcraftservice.com/AsBuilt
I input a vin from a lariat I found in a dealer ad. and downloaded its "as built" data.
Looked up the tire data (09-F3), converted it from hex to decimal (2574) and wrote the result to my BdyCM "Tire Circumference" module.
Ran PCM "Module initialization/relearn" procedure.
Now my speedometer is reading accurately again. 😌😌😌
WhipSticks
Stephen
Maine
2023 F150 Lightning
Scientist
It's a shame that none of the wonks around here could not have helped more directly! But well done! And Gutsy! Were you sweating bullets when you hit "ENTER"?
eRockBoon
Erik
Kansas
What is 726-12-01?
I only changed 726-15-01 and 726-15-02 to adjust my speedometer.
WhiteBolt
WhiteBolt
Ed
CFL
Manufacturing
What is 726-12-01?
Never mind about that 726-12-01. I found out it's only pertinent to 2015-2020 trucks.
I recorded, but didn't edit 726-15-01 and 726-15-02 because it was in the "as built" module.
I only edited "tire circumference" in the "BDYcm" module.
That still corrected my speedometer though. :unsure:
WhiteBolt
WhiteBolt
Ed
CFL
Manufacturing
Not really, but I did a lot of research about Forscan programming before trying anything.
I also made backups of the original data just in case.
