Lost Radio presets
jthiesse13
Phoenix
2023 Lightning
I got in my truck this morning to find that I lost 6 available radio presets. I've had 18 available presets and now it's down to 12. I can't tell if I got an update anywhere (nothing in the Ford Pass App) so I don't know if that's what happened, but why would Ford reduce the number of available radio presets? Am I missing something? How do I get them back?
frautumn
Fred
Northern CA
2022 Ford F-150 Lightning Lariat
Are they lost or do you just need to scroll down to see them? Try using the right arrow button on the steering wheel to cycle thru the presets to see if they are still there.
Webbo85
Marc
Glenmoore, PA
2023 F150 Lightning Lariat ER, 2023 Mach-e, 2002 Jeep Wrangler
Mech Engineer
Assuming the 15" screen. In the upper right hand corner there's a icon of what looks like 2 people. Press that and scroll down, you can change the number of rows of presets. That gets reset sometimes I've seen (no idea why). Select the max number of rows and your presets should reappear.
jthiesse13
Phoenix
2023 Lightning
Yes sir, that was the issue, thanks! I don't know how or why that got changed but after checking I learned that you can have up to 6 rows of presets so that's good to know.
Lucky26
Deep pull but this helped me out. Thank you. Have no idea how it got set to 2 from 3.
pch3
Pete
Vermont, USA
2022 F150 Lightning
Thanks for this post. I (for reasons unknown) had my presets drop from 3 rows to 2... I haven't had a chance to check the solution yet, but it seems more likely than not that this setting will be the case.
