Nav showing wrong location after messing with forscan
fisherjuly2000
Ben
illinois
2022 F150 Lightning Lariat
I was messing with forscan after I got my truck. I put a leveling kit on and 33” tires and wanted to customize it to my liking using forscan. I changed the tire size, enabled matrix headlights, disabled backup beeper, seatbelt, and I think a few other small things. I noticed that now my gps is showing a very inaccurate location and I can’t seem to figure out what the issue is. I disconnected the battery and that didn’t help. I just found something on a different forum saying to do a pcm module relearn to fix the P160A code and that didn’t seem to help. The P160A is the only present DTC. Any advice helps. Thanks.
fisherjuly2000
Ben
illinois
I also just found in the APIM that “GPS from telematic control unit module was disabled. I tried to enable it but that didn’t change anything except now I noticed there’s a red ? Flashing on the nav
flyin525
Richard
Youngsville, NC
2022 Ford Lightning Lariat ER
Gussing you didnt save a backup before making those changes?
There is a motorcraft site where you can get your origional asbuilt data but thats risky since its been so long since its been new.
PSA: NEVER make changes in FORScan without making a backup.
fisherjuly2000
Ben
illinois
I was stupid and thought that it originally saved everything when I saved the stock profile. I just tried to load factory as built on the different modules I messed with and bringing the ipc back to stock actually made the gps go back to where it should be. Now I just need to figure out what I changed in there that caused this
Ford Motor Company
Official Ford Account
F-150 Lightning
Hello! Send us a private message with your VIN and current mileage. Allow me to see what I can do to assist. Thanks!
