OEM Kicker Subwoofer
VictorM
Victor
Western PA
F150 Lightning XLT ER
Experiential Knowledge Griot
I had the OEM Kicker sub installed on my XLT ER (312A) at my dealer. Plug and play with my stock 6 speaker system and the sound is significantly different and better. My next upgrade will be the door speakers and column tweeters. I picked these up and will DIY when the weather gets nicer.
Ford F-150 Lightning OEM Kicker Subwoofer IMG_2321
I don't know anything about the speakers you chose, but it doesn't take much to be an upgrade from the light paper speakers you get from Ford. Truly an insult they put in the trucks for the prices paid.
You can get better speakers for less money. And the bracket that is shipped with the tweeters is useless for the pillar application.
Reactions: GDN
VictorM
VictorM
Victor
Western PA
I have looked for several months and landed on this $1,300 upgrade (including sub/install). Please let me know of the better, cheaper speakers that will fit. Link?
Brent
Murrieta California
2023 F150 lightning
Police
I wanted real bass. I installed two 12 inch Kicker CERT12 in an enclosed box and a CWA kicker 1200 amp. The stock speakers suck. Cost was $1600 installed with a bass knob added.
I'm not saying there is anything wrong with the speakers you're looking at, but If I'm installing speakers that aren't going to be pushed by an aftermarket amp, I'm looking at something with a better sensitivity to take advantage of the stock power.
Personally, I'm looking at the Pioneer TS-A693FH for the front door and the Polk DB 652 for the rear. I'm also thinking of getting the JL Audio 10" PowerWedge. All in, with the speakers and amp install kit from Cruchfield, and the door block off plates and factory sub block off plate from SGS, I'm looking at less than $1200.
VictorM
VictorM
Victor
Western PA
That’s nice equipment and a great price including install.
Madasahatter1138
Vancouver Island BC
Ford Transit
Electronics Tech
I was considering doing this OEM sub as well. Do you happen to know if there was a wiring harness for it tucked away, or did they have to run wires for it? Also, did you see any changes in the audio screen for sound adjustments, or is it still the same three levels?
Did you find the cost was worth the sound improvement?
VictorM
VictorM
Victor
Western PA
it was worth it. The wiring was there and no additional controls are added To the screen. The sound is significantly better just by adding the sub. my Next step is to check Forscan for any changes i can make in the Audio Control Module ( ACM) for the upgrade. You can save $200 if you install yourself.
Madasahatter1138
Vancouver Island BC
Ford Transit
Electronics Tech
Good to know,thanks. Im not using Forscan so would need it installed by dealer so it can be coded in. The sound of the XLT 312a is pretty good, but for those few times were I get to drive it without the dog and kids, I'd like a little more low end.
VictorM
VictorM
Victor
Western PA
I learned from someone on this forum that if you don’t have a sub, go negative on treble and mid, leave bass at mid point and turn volume up.
