On board Scale
Fordphanatic
Boothwyn
2021 Platinum F150
Union Carpenter
Is the on board scale feature something that can be added with needed sensors and forscan or fdrs? Not sure why you cant get on board scales and FX4 package.
Bluesman
Iowa
1965 Factory Five MK IV Roadster
The scales package only comes with CCD shocks.
780
edmonton
2015 F150
I ordered on board scales / smart hitch on my 302a with FX4. Pretty sure I don't have CCD shocks.
Thought you could only get them on Lariat or higher?
Bluesman
Iowa
The OP appears to have a platinum.
Lariat, KR & Platinum from the order guide:
On-Board Scales w/ Smart Hitch (req. Continuously Controlled Damping (61D) 55S
Continuously Controlled Damping (reqs. On-Board Scales w/ Smart Hitch (55S); NA w/ FX4 Off-RoadPackage (55A) 61D
XL & XLT you can split it out.
Fordphanatic
Fordphanatic
Boothwyn
2021 Platinum F150
Union Carpenter
@Jesse-Infotainment whats your take on this? Your the GURU when it comes to adding options/features.
Jesse-Infotainment
Jesse
2024 F150 Lightning Platinum
On board scale would require the VDM and rear shocks and front height sensors.
If you have projector headlamps you would need to add the front passenger height sensor and rear shocks.
You will need the new LED tail lights for the visual indication if you want that.
The other thing is you may need to load JOb 2 software on your apim. I dont think the job 1 even with 22034 has it.
It would be pretty large job.
You basically need to add the CCD suspension. that would require two new shocks up front also.
Long story short anything is possible it is down to how bad you want it.
You also need to reprogram the HCM to get the leveling signal from canbus
