Question about throttle pedal replacement
WildBlue
Somewhere
2024 F150 Lightning Flash
I recently had the throttle pedal assembly replaced under warranty in my 2024 Flash as the pedal was sticking. While the new pedal is perfect and everything is working fine, I wanted to know if this is a repair I can do myself should the pedal fail again out of warranty. There appear to be two bolts that hold it to the firewall, but there's also the pedal height adjustment cable that comes in from above to connect. Anyone have a service manual that could share the replacement procedure?
DM sent.
