Rear Axle "Seeping"
abel408
Schenectady, NY
2023 F-150 Lightning Pro
It appears to be a common issue as I had seen a facebook post from a group member on the rear axle seeping. I haven't noticed any symptoms, but since my factory warranty to almost up, I figured I'd take a look and low and behold, my driver's side axle is showing the same:
Ford F-150 Lightning Rear Axle "Seeping" 20260327_161103
I took it to the dealership and apparently, the seal is "seeping", but not leaking. It needs to be dripping in order for it to be covered under warranty. The good news is that it would still be covered under the powertrain warranty, so I have another 2 years to keep an eye on it, but I think it's bull that Ford won't replace something that shows signs of failure. Is anyone else in this boat? I'm sort of hoping it starts dripping so that it can be fixed before my powertrain warranty is up.
struckby
Richard
Atlanta, Ga
24 mach e premium hunting a lightning
Refrigeration Mechanic
Bet with a syringe and some hot gear lube it would start dripping.
3rd rock
Automotive Technician
struckby
Richard
Atlanta, Ga
I thought it was at the cv joint.
struckby
Richard
Atlanta, Ga
I now see it is at the rear diff. So yes, atf could be added in a neat manner to cause drip.
