...just completed replacing original LIGHTNING '22 PRO SR Gear Shifter with
new ROTARY DIAL PZ1P-7P155-AC...
and, tried an 'easier' route to NOT having to remove upper trims and entertainment/button panel...
FIRST:
A) removed the small cover inside the front of the Shifter's 'stow away' housing, then removed the 'bolt cover', using a straight edge driver to release the clip
B) removed the 10mm bolt
C) turned the truck to accessory mode, and 'Stowed' the shifter, using the stow button
- turned the truck off
then:
- carefully pried/pulled driver side 'chrome' side trim away from center console, by hand - carefully, all the way back to just under the 'ON' button area... and pulled back away far enough to allow the center console 'trim' cover to also be pried off a little ways... the driver seat may seem to be in the way, but the trim should be flexible enough to work out out and over the seat for more room away from the center console
- carefully pried the passenger side trim, the same way...(SEE PHOTOS)
- carefully pried the rear edge of the center console trim cover(just inside the front of the center storage area), using a trim tool(a straight blade screw driver would probably also work, carefully)...once it pops up, carefully pried the rest of the center console up as high as optimal, slowly... just to start to see that the shifter assembly may just be able to then squeeze out this area...*
* the right side cup holder has a ELECTRONIC plug below that can be detached(use a straight edge driver to press the rear clip), to then allow the center console to have more flexibility.(I believe this is the 'keyfob sensor' that provides for turning the truck 'ON' when the keyfob is placed here, if the batteries are low/dead)
- while this center console trim is pulled up, use the same socket to take out the rear two BOLTS
- now, this is where it gets fun: there is ANOTHER bolt, hidden at the bottom right front of the Shifter assembly, and HARD to see, much less to manage to get to with a socket wrench - I used my flashlight to leverage up the trim as high as possible, and to see down into the inside under the assembly, and used a socket 'extension' and the socket to get down and onto the bolt - it was just short enough to allow me to use the socket ratchet to attach to the extension and get a 'start' at breaking the torque on the bolt - then I just used the extension, itself, by hand, with several fingers, to slowly rotate the bolt enough to get it starting to turn - it took a long while to rotate it enough times to get it released.
- the Shifter has an Electronic PLUG on the rear driver side of the unit. While it may seem that you simply pull back on the gray 'release tab', what you actually have to do is PUSH IN the release clip in front of it, first, with a straight edge driver... it will then 'pop' as it releases, and then you can pull back the gray tab and release the whole plug...
- now, the Shifter Assembly is ready to be removed, although, like me, you just may want to plug in your new ROTARY DIAL, first, and take the truck for a test ride. I did this in my driveway. At first, the truck seem to send some icons and alerts, and you may even have to just let it go thru the motions before you jump to conclusions that there is any issue: I heard some dings, I saw some wrench icons, and 'door open' alerts, and even 'go to your dealer asap!', and others, but I just made sure the truck was ON, then I turned the DIAL to 'D', and the truck released the brakes, and I moved forward.
I realized almost immediately that AUTO HOLD was not engaging, and simply went back into the 'Driver Assist' settings, turned it back ON, and it started working again.
I put it in Neutral, pushed the 'L' for Neutral Hold, and it also worked.
I used REVERSE, and it worked.
All good.
- so, now that it all works, I unplugged the new dial, and started to remove the Shifter Assembly. This takes some leveraging of the center console trim cover, but it WILL allow it to come out. It is a big unit.
- and, since I don't yet have my Manionmakes 3d-printed insert yet, I simply re-plugged the new ROTARY DIAL, added some hats inside the center console cavity for support, and will use it like this, until then... fun!
Shifter stowed, and console trim and cover removals...
only stow shifter AFTER removal of the bolt underneath it...
Ford F-150 Lightning SUCCESS! ROTARY DIAL installation with  12" screen - without removing upper trim Shifter stowed center console trim cover
remove this 'cup holder' plug for more flexibility of the cover...
remember to replugging it afterwards, or you may have some
'alerts' from the truck...
Ford F-150 Lightning SUCCESS! ROTARY DIAL installation with  12" screen - without removing upper trim Keyfob sensor plug below passenger rear cup holder
using my flashlight for leverage and holding up the cover...
allowing for removal of the Shifter Assembly
Ford F-150 Lightning SUCCESS! ROTARY DIAL installation with  12" screen - without removing upper trim Removed SHIFTER ASSEMBLY
Center Console Shifter cavity: 4 bolts
Ford F-150 Lightning SUCCESS! ROTARY DIAL installation with  12" screen - without removing upper trim center console Shifter cavity
Complete! with Blue night light....................cavity INSERT installation to follow...
Ford F-150 Lightning SUCCESS! ROTARY DIAL installation with  12" screen - without removing upper trim unnamed
Ford F-150 Lightning SUCCESS! ROTARY DIAL installation with  12" screen - without removing upper trim Success - ROTARY DIAL works
ScottyMcQueen
Scott
2022 Ford Lightning Lariat
Business intelligence
I just did this modification myself. There is a great video on youtube if you search for replace lightning shifter. Took me 15 mins to remove.
I ended up buying 2 of the 3d printed pieces to hold the shifter. First one was ordered middle of july and never shipped. I ordered 2nd one with a cupholder and it shipped next day.
Warning, do not use semi gloss paint. See below. Its not even close
Ford F-150 Lightning SUCCESS! ROTARY DIAL installation with  12" screen - without removing upper trim 20250907_121528
ScottyMcQueen
Scott
Lol your hats filler is very creative!
right, but us 12" screen trucks have a few more 'steps' of trim and radio removal because of the way the trim was installed 'underneath' the entertainment button facia... these steps just remove the 'requirement' to have to take those steps, if you wish...
yes, LOL... I had to find SOME use for all those things... how in the world did I collect so many?? : )
Manionmakes responded last night that he is shipping out the Rotary Dial INSERT... I'll also be adding a 'pass thru' for my phone wireless charger STAND(USB-c) that will sit down into the front cubby of the INSERT...
it holds and charges in both Portrait OR Landscape...
Ford F-150 Lightning SUCCESS! ROTARY DIAL installation with  12" screen - without removing upper trim 1757421167084-9d
this is also the Rotary Dial with a 'blue tint' at the base of the ring, only seen at night... and has a firm 'turn' of the dial, and does not continue beyond 'D', drive.
Ford F-150 Lightning SUCCESS! ROTARY DIAL installation with  12" screen - without removing upper trim 1757509954303-5s
SUCCESS! finished and installed..... perfect! thanks to @manionmakes [Etsy - manionmakes ] for the perfect 3D printed drop-in Rotary Dial cubby, and a perfect place for my existing USB-c Wireless CHARGER Stand - it fits into the front drop-in so exactly! Wow!
comes with 4 correct sized screws, too... just tighten the Rotary Dial unit onto the rear of the 3D insert cubby...
Ford F-150 Lightning SUCCESS! ROTARY DIAL installation with  12" screen - without removing upper trim IMG_1551
I found that it was also easy to slip in the cubby insert into the empty cavity, while lifting up on the console insert cover... I re-plugged the Rotary Dial harness, first, and turned on the truck to see the 'lights' of the dial glowing... good stuff!
Ford F-150 Lightning SUCCESS! ROTARY DIAL installation with  12" screen - without removing upper trim IMG_1552
use one of the original bolts down into the front, then add the included 'cover' for this hole
Ford F-150 Lightning SUCCESS! ROTARY DIAL installation with  12" screen - without removing upper trim IMG_1553
I used a socket on the passenger side rear bolt to easily start snugging it up, while lifting up the console insert cover
Ford F-150 Lightning SUCCESS! ROTARY DIAL installation with  12" screen - without removing upper trim IMG_1555
The driver side rear bolt, too....
Ford F-150 Lightning SUCCESS! ROTARY DIAL installation with  12" screen - without removing upper trim IMG_1554
yo can then get a socket wrench on both...
Ford F-150 Lightning SUCCESS! ROTARY DIAL installation with  12" screen - without removing upper trim IMG_1556
then snap the center console insert cover back down, maybe with a few firm 'bumps'
Ford F-150 Lightning SUCCESS! ROTARY DIAL installation with  12" screen - without removing upper trim IMG_1557
then carefully and firmly tap the driver and passenger side trims back in
Ford F-150 Lightning SUCCESS! ROTARY DIAL installation with  12" screen - without removing upper trim IMG_1558
the bolt cover is snapped in, too
Ford F-150 Lightning SUCCESS! ROTARY DIAL installation with  12" screen - without removing upper trim IMG_1559
here's the final picture, with the wireless charger sitting perfectly in place : )
Ford F-150 Lightning SUCCESS! ROTARY DIAL installation with  12" screen - without removing upper trim IMG_1560
so nice : )
I've noticed some things, too, with this new ROTARY DIAL PZ1P-7P155-AC version
A)It does NOT rotate 'back', mechanically, on it's own, if you turn OFF the truck without yet turning it back to 'PARK', it simply changes the lighted letter from 'D' to 'P'
also, seemingly different than my 'original' Gear Shifter Handle:
B)It does NOT rotate out of 'DRIVE', if at a stop, with Auto Hold, when I OPEN the driver door - it simply applies the parking brake, and REMAINS in 'DRIVE' (if you then press the GO pedal, it will also RELEASE the parking brake and move forward, still with the door open)
now I just need @manionmakes or someone to design a elevated 'desk' top that can sit above the Rotary Dial/Storage area when needing to use the area for a laptop, at the same level as the center arm rest...
maybe with extendable 'legs' that simply straddle the front and rear of each side of the storage area edges...
high enough to be level with the arm rest, and also to clear anything already in the storage area... such as a coffee mug, water bottle, etc.
2 questions.
What material did you order, and do you have a link to the wireless phone charger?
HI Zeus
Craig
New Mexico / Hawaii
2023 Lightning XLT, 2013 Kia Optima Hybrid, 2003 F350, 1989-93 BMW Paris Dakars
SO retired!
I like that the dial physically stops at "D," as I hand wondered if I'd have to be very attentive (looking) as to where it was pointing, or could just do it by muscle memory/feel like a shifter. Does it also physically stop on the other end of the rotation, "P" since most of the time those are the two points I'd be going between that would mean I usually could just reach down and blindly spin in one direction or the other.
So, in the situation you describe in "A": I assume that NONE of the various dials rotate back on their own? Is it actually in park, or is the indicator incorrect? On restart, how would you get the indicator light and dial orientation "recalibrated" to be in synch again?
think about the physical turning of the dial as simply another 'input', electronically... it really doesn't matter 'where' the dial is, only that you are turning it one way or the other - the truck already knows what gear it is in...
some dial variations have been reported to mechanically 'move' back, such as the original Stick Shifter did, which would 'move' mechanically back to 'P' if you opened the door, turned off the truck, etc., while in 'D'...
on 'restart', as you ask, the dial will ALWAYS already be in Park 'P', of course. It's electronic.
