- First Name
- CHRIS
- Dec 16, 2022
- alexandria virginia
- 2023 LIGHTNING PRO, 2012 Nissan Leaf, 2015 Toyota Prius, 2000 HD 883 Sportster
- Occupation
The 50% Rule: Maximizing AGM Lifespan
The most critical takeaway from the SoC chart is the 50% mark (12.2V to 12.3V).
Deep-cycle AGM batteries are designed to deliver optimal lifespan when their Depth of Discharge (DoD) is limited. Repeatedly discharging the battery below 50% significantly reduces its overall cycle life.
For optimal performance and longevity, AGM batteries should be charged using a smart charger specifically designed for AGM batteries. A three-stage charging approach is generally recommended for AGM batteries. For a typical 12V AGM battery, the recommended charging voltages are 14.4V–14.8V during the bulk/absorption phase and 13.2V–13.8V during the float phase. Improper charging practices, such as overcharging, can accelerate degradation and shorten the lifespan of AGM batteries.
For long-term storage, an AGM battery should be kept as close to 100% SoC (12.8V) as possible and maintained with a proper float charge 13.4V to 13.8V.
- Goal: Keep your AGM battery above 50% SoC 12.2V as often as possible. This ensures the battery can reliably deliver power when needed and helps prevent capacity loss.
- Avoid: Never discharge an AGM battery below 11.8V (0% SoC), as this results in severe, permanent damage due to hard sulfation.
