Turn off Reverse Brake Assist Warning Message?
grantmethepower
Grant
LA, CA
2023 F-150 Lightning Pro
Hi, has anyone figured out how to turn off the warning that you have reverse brake assist turned off? I found the line in Livnitup's Forscan guide (it's even listed under "common") but it doesn't seem to work on my 2023 Pro. If I change the indicated flag in FORscan (706-01-01) as found on the guide, I get a IPMA error and pre collision assist and driver assist no longer works. The DCT error I get is that the module cannot be found. Switching that one number back to the original fixes it.
I'm thinking there must be a way but it is a different set of codes. I also tried 706-12-01 as well trying the combination but no dice there either.
Anyone figure it out?
Grumpy2
Central Oregon Coast
23 F150 Pro SR
Retired Hvy Construction
Check page 242, under Features - Driver Assistance
grantmethepower
grantmethepower
Grant
LA, CA
That is only to turn the feature on or off.
I prefer it turned off. The issue is that when it is set off, the driver display has a pop up warning every time that says “reverse parking assist off press ok” and it is annoying
using forscan my understanding is that you are able to stop that warning from appearing and that is what I’m trying to do.
