Un-Modifying my Truck
UWdave
2023 Ford Lightning Platinum
Just bought a 2023 Platinum w/ 27k on it.
Previous owner installed:
- 2" front lift (~1" puck above the shock/spring)
- ~1.5" wheel spacers
- 305/45R22 Nitto MT's
I plan on removing the lift ASAP as I don't like the axle angle and the extra lift on acceleration.
Will the wider tires rub without the lift?
Once removed I'll check clearance without spacers, I just didn't want to go through the hassle of lift removal before knowing. I'd like to run the tires through summer.
Heliian
1.5" wheel spacers
They really should outlaw wheel spacers. I would remove them and see if the wheels fit when de modded. The tires are actually a smaller diameter than stock but over an inch wider. If your rims are offset that will also make a difference(not sure if you are on stock rims).
UWdave
Tire calc I did shows the height difference is nothing/trivial:
275/50R22 - 32.8" radius / 103.1" circum. / 10.8" wide
305/45R22 - 32.8" radius / 103.0" circum. / 12.0" wide
So the tire will be ~0.6" closer to the shock and fender while turning.
Stock wheel, not a fan of big wheels. Will consider dropping down to 18" when I replace the tires.
Heliian
You'll have to check the clearance. I found last year when I installed some new rims with a positive offset that the clearance to the fender was reduced quite a bit while turning. I'm on 275/60r20. The 20s are great.
Andrewbens
Modesto
Lightning
Mechanic
Why there is nothing wrong with them at all especially Hubcentric spacers.
