USB ports fast charge??
zdjelar
Saša
Houston
2021 F150 Limited (AMB)
Energy
I wonder if every version has the same outputs, yours seem a production unit but look at this pic, it's different
This trim also doesn’t have the wireless charger.
Dsmenardvt
Dan
Vermont
2022 F150 501A SCrew 6'7" Antimatter PB
Concrete
Anyone get a solid output level for the USB C port?
sbi
Upstate SC
2021 F-150 5.0 Lariat SCREW Space White
The USB ports do not provide fast charge. I cross checked with several USB cables in multiple devices. Cables with 12V USB adapter that provided Fast Charging did not Fast Charge when plugged directly to either front USB ports.
That's in my truck, anyways.
daemonic3
Terry
Sacramento, CA
2017 F150 3.5EB
I don't use the front center stack USB or wireless chargers because I keep the slide door closed, but I can verify that the USB-C inside the center storage armrest is very fast. I don't think it is full Qi charging but it certainly is faster than the 2-Amp USB-A port from the storage. I just have two 3ft cables connected inside there and pull out as much cable as needed from the feed-thru notch. On long trips the wife and I will trade for "the fast one" based on percent battery needs.
PrivateJoker
2023 Lariat ER, Telsa MY, 12 Leaf, 18 Leaf
Shame it's not 65W or greater.
But If I'm being honest, I would care more if I didn't have 120V A/C, 12V, and basically the kitchen sink.
