Weird Charging Issue -- Possibly after module replacement
AntJohn73
Anthony
New Jersey
23 Lightning Lariat
I am figuring that this is exactly what my truck needs.
Mpi
Brant
2023 lariat ER
My dealer has confirmed a full balancing is needed. The service rep told me the original instructions from Ford were to balance the new module to match the battery. Now Ford tells them a more involved balancing is needed where each module, new and old, will be balanced and the voltage set to some common level before reinstallation. I'm not sure how accurate all that is, but it's what I'm told.
So such a condition as we've been discussing does exist, and it won't necessarily throw a wrench light or brick the truck. If you are aware enough of your vehicle this should be a good thing.
Another update: in the process of balancing they found that one of the replacement modules was bad.
So it seems that in fact even a bad module might not throw a yellow wrench! It still seems like a good thing that the truck remains driveable, but you'd think there should at least be an indicator light for a bad module.
GoodSam
Good
occupying space
How many replacement modules did you have done for the Safety Recall 25S18 back in October, 2025? And, just to confirm, one of those new modules put in went bad? Yipes!
Mpi
Brant
2023 lariat ER
I need to clarify with the dealer whether the bad module is the new one. Looking at my charge history, I suspected is was bad out of the box because it 'falsely' charged to 100% the first time the dealer charged it.
Mpi
Brant
2023 lariat ER
I'm not sure how @AntJohn73 has fared, but for me the saga continues.
I got a call end of day yesterday that my truck was ready. A battery module was replaced, the BECM module was replaced, and the truck successfully charged to 100%. Great! (@GoodSam I clarified the replaced module was not in fact the one that went in under recall 25S18).
As I left this morning to pick it up I remotely started the climate, observing 100% SOC indeed. I arrived 15 minutes later to find it at 69% SOC. I told the rep it was weird and familiar behavior. The service manager came out to talk to me, and we agreed to plug it in to charge for half an hour while I dropped off my daughter. Of course, when I got back it was fully charged to 100%.
Replacing the BECM was due the Ford engineering's theory that it had caused the module failure. Back to the Ford engineers now to figure this out. The good thing is that the dealer is very supportive and has me in a nice loaner, albeit an ICE truck.
LiteNing
Nic
'23 F-150 Lightning Lariat ER
1's and 0's and lambdas
I might as well post my update too:
Dropped off the truck last week Thursday. I wrote down my symptoms in the reservation (basically same as Mpi and AntJohn73) and also explained the same verbally to the service writer.
To help them diagnose the issue as the HV battery, I also mentioned that supercharging slows down at 72% instead of the expected 80% (8% early)... just like the top 8% of the battery is unusable. That may have been a mistake.
Friday the diagnosis came back that I needed a new charge port. Sensor is reading 400F. I asked if they ran any HVB diagnostics... nope. They claim the workshop manual says they need to do the charge port first. 🙄
So for anyone in the future with this problem: Maybe don't mention the supercharging symptom if you have it.
The charge port is covered under the 100k/8yr warranty, but the service writer said it's hard to replace without damaging another part that isn't covered. Good thing I got an extended warranty...
They're supposed to have the charge port done today. I'm cautiously optimistic that today they will actually start the HVB diagnostic.
GoodSam
Good
occupying space
AntJohn73
Anthony
New Jersey
23 Lightning Lariat
@Mpi This is my update. It turns out that there is a second bad module. The module is on order. They allowed me to take possession of the truck until the module arrives. That turns out to be a good thing because we are expecting a decent amount of snow this weekend. I has a Ford Edge as a loaner (yuck). I will be bringing it back in February. Hopefully everything will be resolved. One thing I will say is the dealership has been very respectful and nice to me. I just hope this is the last part of the saga. It sucks because the truck is excellent and has such a smooth ride.
Reactions: Mpi
LiteNing
Nic
What is the build date, & miles at problem, showing on your trucks (driver's door sticker)?
Door sticker says date is 12/22 (had to find a picture from a few months ago). Current milage is ~47500, but I would estimate I saw the first symptoms around 46k, maybe as early as 45k.
The previous module replacement was at 40k miles.
