AntJohn73
- First Name
- Anthony
- May 16, 2024
- New Jersey
- 23 Lightning Lariat
I am figuring that this is exactly what my truck needs.
Another update: in the process of balancing they found that one of the replacement modules was bad.My dealer has confirmed a full balancing is needed. The service rep told me the original instructions from Ford were to balance the new module to match the battery. Now Ford tells them a more involved balancing is needed where each module, new and old, will be balanced and the voltage set to some common level before reinstallation. I'm not sure how accurate all that is, but it's what I'm told.
So such a condition as we've been discussing does exist, and it won't necessarily throw a wrench light or brick the truck. If you are aware enough of your vehicle this should be a good thing.
How many replacement modules did you have done for the Safety Recall 25S18 back in October, 2025? And, just to confirm, one of those new modules put in went bad? Yipes!in the process of balancing they found that one of the replacement modules was bad.
I need to clarify with the dealer whether the bad module is the new one. Looking at my charge history, I suspected is was bad out of the box because it 'falsely' charged to 100% the first time the dealer charged it.How many replacement modules did you have done for the Safety Recall 25S18 back in October, 2025? And, just to confirm, one of those new modules put in went bad? Yipes!
Door sticker says date is 12/22 (had to find a picture from a few months ago). Current milage is ~47500, but I would estimate I saw the first symptoms around 46k, maybe as early as 45k.What is the build date, & miles at problem, showing on your trucks (driver's door sticker)?
Another week another update. They finished the charge port! Service writer called me on Friday with the happy news! Did they diagnose the HV battery, like I asked last time we spoke on the phone? Uh, no, but the charge port is fixed! Did they at least test the very specific symptoms that I wrote down when making the service appointment and then reiterated verbally to the service writer on the phone? Well no, but the charge port is fixed!I might as well post my update too:
Drive and charge, typically what's meant by time.I wanted to post what I am hoping is my final update. The dealership replaced module #2 and I have taken possession of the truck. It successfully charged to 100% and the charge curve appears to be normal. On a level 2 charger, the charge current does not start to ramp down until it is over 90%. My variance between modules is now at 2% as opposed to over 20% when the issue was occurring. My scan tool indicates that the battery is in a state of re-balancing which I think is normal after this type of work? Any tips on how to achieve a balance sooner?
Great to hear. L2 charge to 100% and let it sit overnight, should go a long way towards balancing out the remaining 2%I wanted to post what I am hoping is my final update. The dealership replaced module #2 and I have taken possession of the truck. It successfully charged to 100% and the charge curve appears to be normal. On a level 2 charger, the charge current does not start to ramp down until it is over 90%. My variance between modules is now at 2% as opposed to over 20% when the issue was occurring. My scan tool indicates that the battery is in a state of re-balancing which I think is normal after this type of work? Any tips on how to achieve a balance sooner?
