Will 34s fit on a reverse leveled truck?
dothedew
Colorado
Basically the title. If so - what part do I need to reverse level a short bet super crew powerboost without FX4?
if not - does the 2022 need a 2” or 2.25” to be perfectly level in the front?
Tizzzo
Ed
2021 Lead Foot Gray XLT 5.0 Supercrew 4x4
Veteran
Depends what wheel and what size tire you’re going with. I’ve seen members here run up to a 295/70/18 (34.3) stock without a level on stock wheel and offset. If you have an fx4 a 2 inch level will still leave some rake left so a 2.25 inch would be better. If you’re interested I do have a ready lift 2.25 inch leveling spacer set for sale.
DT444T
Jake
21 AMB Powerboost Lariat
Meat servo
When you say "reverse level" do you mean lowering the rear to match the front to level it?
Moroney167
Newburgh NY
2021 F150 5.0
I have a Lariat Sport. Max tow package. 4 door 6.5ft bed. Removed factory 1.25 (approx) rear block. truck sits perfect not unlevel at all. even with 700lbs in bed not unlevel.
Ford 22 wheels with Toyo AT3 295/55-22 and they dont rub one bit. Required a shim 1/8" spacer on front wheels to clear upper ball joint safely.
But if your questions is what you have to get or buy, is nothing. Just loosen rear axle u bolts. Have a floor jack and perhaps a jack stand. I didn't even remove my wheels. Once you remove factory lift block (between axle and leaf spring), and aline pins on springs to axle. Retorque in cross pattern the U bolts. I do not remember tq spec off hand and enjoy. Recheck U bolts in 100 miles or sooner. Someday I'll take better pictures of truck. Once I got it went right into winter here in North. Yet to roll windows or open sunroof...
Ford F-150 Lightning Will 34s fit on a reverse leveled truck? 5561C8CA-757A-4CC5-B2A7-4F028D8B8AEE
Zyvin
SC
2021 F150 Crew, FX4, Lariat
You should be fine. There is way more room in the back and you aren’t changing the front, in which people are already running 34s.
