Wiper recommendations?
Maxx
I learned early on that you don't need to replace the whole blade mechanism. You can just replace the rubber bit. These are good and can be cut the desired length.
https://www.amazon.com/dp/B0CYZHQ7HZ?ref_=ppx_hzsearch_conn_dt_b_fed_asin_title_1&th=1
‘Did you use this on Lightning? The dimension on this rubber seems to be different than what I have. This one is 5 x 10 mm. Please let me know if you actually have used this successfully so I can order it.
p.s. I have a 23 Pro. (22 in blade). Not sure if blades are different in different trims.
Ford F-150 Lightning Wiper recommendations? 1774221040541-98
Maxx
Yes. They work on the lightning .
For anyone reading, I installed this today in 30 seconds. It is smaller than what came off of the blade but It does fit. I will post later if there is any performance issues.
Ford F-150 Lightning Wiper recommendations? 20260327_110607
Ford F-150 Lightning Wiper recommendations? 1774624726641-f3
Tom M
Bossier City, LA
2022 F-150 Lightning Lariat, 2025 VW ID.Buzz
Pilot, Instructor
I use the Bosch Icon 22A and 22B. I am in Northern Va and they do great in the Mid Atlantic weather.
This is what I’m using as well: Bosch Icon 22A 22B. The useful life of the OEM blades seem shorter than expected, I’ve only had these installed since November so I can’t comment if the Bosch last longer. They were readily available locally.
