vandy1981
Tennessee
Plumber
The Lightning did great with a short trip to a state campground 55 miles away from home. As usual, towing was effortless and we averaged between 1.0-1.1 mi/kwh with the trailer attached. The ability to fill the truck's tank for free at the campsite was an added bonus.
Ford F-150 Lightning A short weekend camper trip with the Lightning -- averaged 1.0-1.1 mi/kwh with trailer attached 20220821_093637
Ford F-150 Lightning A short weekend camper trip with the Lightning -- averaged 1.0-1.1 mi/kwh with trailer attached 20220821_093557
Puppy tax:
Ford F-150 Lightning A short weekend camper trip with the Lightning -- averaged 1.0-1.1 mi/kwh with trailer attached 20220820_080110
Dadvikefan
Western NC
2016CmaxEnergi,2017,FusionSE,Future Lightning
Chef
What did you have on top of the I-pace?
Griddlez
Griddlez
Metro-East of St. Louis, MO
Great efficiency - can I assume sub 60mph speeds?
We went this weekend as well and averaged .8-.9 on the way there and .7-.8 on the way back fighting a 10-15 MPH headwind. Cruise controlled at 65mph both ways.
90 miles 1 way. On the way there truck said I had 30 miles left, on the way back it said I had 15. Charged fine using the 50 amp at the campground. Had charger set to 32amps. Tried 40amps but it threw the breaker. Set back to 32 and worked fine.
Ford F-150 Lightning A short weekend camper trip with the Lightning -- averaged 1.0-1.1 mi/kwh with trailer attached 20220821_112944 - Copy - Copy
johnnyonetime
FL
2022 Lariat ER
Did you plug the camper into the Lightning?
Griddlez
Griddlez
No, didn't try but I should have. Our pedestal had a 30 amp plug (our camper is only 30 amp) and a 50 amp plug. Kept the charger on the 50 amp plug set to 32 amp pull; they both ran fine off the 1 pedestal.
Firestop
Firestop
Did you use the Ford Mobile Charger or another brand?
vandy1981
vandy1981
Tennessee
Plumber
Griddlez
Griddlez
I brought this one along:
https://www.amazon.com/gp/product/B09NPF2CL8/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
So I could adjust (unlike the ford one) -- altho I believe the Ford one would have worked just fine in this case. Also I saw a post out there today about the charger(s) not working in rain - we had a serious down pour and the unit charged through it no problem. I also wouldn't expect the ford one to have any issue either.
vandy1981
vandy1981
Tennessee
Plumber
Nice report, did the pedestal ever get hot? I went to a State Park this yesterday and plugged in and that 50amp box got real real real hot.
I didn't check.
swngdncr
Carla
2016 Toyota Forerunner, 2016 Subaru Outback
retired mostly
Puppy tax:
Thanks for the write up. Out of curiosity, what are the specs on your trailer, size, weight and how fast where you driving?
swngdncr
Carla
retired mostly
Same question as for the OP, wondering what the specs are on your trailer, size/weight? Thanks
Griddlez
Griddlez
22.5ft Long
Just under 11ft tall counting the A/C
8ft Wide
max weight loaded is 6800 but I most likely run it around 6000-6200.
Tongue Weight is around 680lbs
vandy1981
vandy1981
Tennessee
Plumber
7x11x22, 4100 pounds. Mix of 55 mph to 70 mph.
