School me (us) on smart chargers
Fordskeptic
Chevy
631Belle#
Chevy, toyota, honda, jeep
Is there any advantage to Ford's 48A Connected Charge Station versus say Charge Point, JuiceBox, etc.? Assuming equivalent amperage is offered. I can get a $500 rebate from the utility for the CP, or JB smart chargers, so thinking that's the way to go.
shutterbug
Phoenix
ChargePoint gives you an option of hardwired or plug in. Initially Ford Charger had a number of issues, that have been resolved. If you're getting $500 rebate, that's definitely the way to go. I've had ChargePoint since last November and there have been no issues.
I am assuming that you are planning on standard battery. Because large battery already comes with Ford's 80A charger included.
frautumn
Fred
Northern CA
2022 Ford F-150 Lightning Lariat
The standard battery comes with the 32-amp Ford Mobile Charger. This will charger a standard battery overnight at 240V in 14 hours, which is good enough for me. What does a 48A smart charger give you other than additional amps (ie shorter charge time)? I assume the "smart" stands for something?
Hamtech
Madison
KIA Sorento, Tesla X
Lawyer
There is no advantage. Honestly if you’re doing basic daily point A to B driving and a few errands a 14-50 outlet and the supplied charger will be more than enough.
I have a Tesla Model X Long Range Plus and the supplied charge plugged into a 14-50 is more than adequate.
The smart feature chargers let you schedule charge start and stop times. It is my understanding that you will be able to do this in the Lightning, as you can in the Tesla without a smart charger.
The thing is if you can get a charger for free from your utility I would snag it and keep the plug in charger with your truck for when you spend a night a friend’s house that does not have a charger.
metroshot
Pat
Montclair, CA
2022 Lariat F150L + 2023 MME
Networking Tech
The thing is if you can get a charger for free from your utility I would snag it and keep the plug in charger with your truck for when you spend a night a friends house that does not have a charger.
This is correct.
The OEM L1 charger that came with my Honda PHEV is in the trunk for travels & overnight stays at a hotel charger or public charger.
The L2 charger installed in my garage was paid for mostly by my utility company and is on a TOU (time of use) meter which lowers the $ per kWh.
I assume the Lightning will be programmable when to start and stop charging for those that use TOU.
adoublee
Midwest
2 EVs
It can schedule charging sessions, so you can plug in but it won't initiate charge until lower cost charging period for example. Utilities like to rebate "smart" chargers that feed them your charging times/rates over the internet connection.
When you get into public charging, "smart" allows access control, payment processing, group power limitations, etc.
Brian Head Yankee
Brian Head, UT
You nailed it. I am leaning toward the JuiceBox 48 because it also talks to Alexa. I have over 30 Alexa devices in my automated home o_O so why not one more? I will use my 80 at my cabin or sell it.
adoublee
Midwest
2 EVs
"Alexa, warm up my truck". Do you know if there is vehicle integration to allow this?
TRP
Tim
TN
2021 Mach E Premium 4X, 2018 Ford F150xlt Sport
If it's like the Mach E in this respect, you can schedule departure times in the vehicle and it will either warm or cool the vehicle so it's ready to go when you want. That will have nothing to do with what ever EVSE (charger) you choose to use
shutterbug
Phoenix
Pretty sure that ChargePoint also integrates with Alexa.
Fordskeptic
Chevy
631Belle#
If I understand the advice, the Lightning PRo SR can be programmed to do the things a smart charger does, like schedule charge times off peak, limit charging to a set percent max. (which can be changed as needed, say 70% for daily commute, 90% for a longer trip or planned towing, etc) schedule a warm up on cold days, etc. But if I get a smart charger with a $500 subsidy take it and keep the 32A charger included in the purchase price for whenever needed. There is no benefit in Ford versus other brands 48A chargers. The smart chargers do the same clever things that the Lightning can be programmed to do.
Did I get that right?
TRP
Tim
TN
The smart chargers log your charging sessions and give you a much better picture of where your electricity is going. That's their advantage.
The truck has the capability to do the things you said as far as charging schedule etc.....
The other advantage of getting a 40a or a 48a "charger" is the increase in charging speed. Translating to less time to get to your scheduled charge limit
adoublee
Midwest
2 EVs
Most likely correct that there won't be a benefit of Ford 48A EVSE over other 48A EVSE's. However, some of the functions you are referencing are vehicle programming versus EVSE programming. A level 2 EVSE won't know the vehicles charge percentage, can't initiate a vehicle warm-up through the wired communication ports, etc.
Some 48A EVSE's might even be better than the Ford one. For example, ChargePoint's cables stay more flexible in cold temperatures than most all others. There are other nuisances between brands like holster quality, display, warranty, UL listing.
However, if Ford is going to supply the same EVSE to fleet owners it is possible their devices will have functionality like Near Field Communication for credentialing built in, but that get's into speculation as I don't think an EVSE spec sheet has been published.
Then, it's a completely different story with the Ford 80A charger, which is what will enable direct vehicle-to-home (potentially vehicle-to-grid in the future) power. This functionality will work with the SR battery, it's just that the 80A charge has to be purchased separately. Again, no specifications published for this other than it being 80A.
Reactions: Joe
Fordskeptic
Chevy
631Belle#
Thanks for all of the input.
As follow up. I am thinking to wait until closer to when I expect to take delivery of the Lightning (probably late 2023, I'm guessing) to get the charger and risk (what I think is a low probability) that the rebate may not be available then. My thinking is that charger technology may improve in the next year or 2.....maybe not at the pace of battery technology, but appreciably.
Does it make sense to wait?
shutterbug
Phoenix
Don't forget that Ford and JuiceBox 48A charger cost $100 more than ChargePoint and Wallbox.
