Off-road Lighting Mounts
Pinero
Jordan
Down the bayou.
2021 Lariat Sport 5.0 SCREW FX4
High Voltage Technician
Anyone aware of aux lighting mounts becoming available for the 21?
dre276
andre
NJ
2018 F150XLT, 2021 F150 XLT 302A Lead Foot
nope, I basically made my own. FYI, the 2021 grill interior space is now smaller than previous and wont fit light bars. I made my own back brace and mounted light bars on the front of the grill.
Ford F-150 Lightning Off-road Lighting Mounts image0
Ford F-150 Lightning Off-road Lighting Mounts image1
Ford F-150 Lightning Off-road Lighting Mounts image4
DanielG
Daniel
2021 Ford F150 Lariat
Tractor Supply sells wireless switches to control sprayers. These same switches can be wired to lights and the remote for the switch can be programmed to the garage door opener switches in your truck. This is how I put lights on my old truck without adding switches in the cab. Worked good for me but I haven’t used it on the new truck yet but I plan to.
KartRacer25
Richard
San Diego
2021 F-150 SuperCab Sport 4x4 5.0 3.73 Space White
Senior Software Engineer
Research:
I found a couple cowl/a pillar mounts online. $22, $65, $114
Looks like this is a mount that will actually be correct and not behind antenna.:
https://www.stage3motorsports.com/z365711-18-21-f150-zroadz-a-pillar-led-light-pod-mounts.html
Just ordered them from Stage3 $60.
FOund another mount:
https://www.americantrucks.com/f150-luminix-hood-mount-light-brackets-2222.html
Baja Designs has some complete kits for 21. Some delays. Supposed to be available ina coupe of weeks.
https://www.bajadesigns.com/products/Ford-F150-21-On-A-Pillar-kits.asp
You can order mounts separately (3 bolt). Parts 449242 driver and 449243 passenger.
I think mounts and harness are available now. But I think they end up behind antenna still.
I got old style amazon 2 bolt mount version by Dasen for $23 and had to dremel it a bit to get light base to go through and installed BDs universal kit.
Passenger is behind antenna but oh well, works. Seems some of the new ones are too.
Came out nice, good and solid, will test next weekend on a desert overnight.
Unless I get the new ZROADZ mounts before that.
Ford F-150 Lightning Off-road Lighting Mounts 20211021_094957
Ford F-150 Lightning Off-road Lighting Mounts 20211021_101924
Ford F-150 Lightning Off-road Lighting Mounts 20211021_141325
Ford F-150 Lightning Off-road Lighting Mounts 20211019_165717
djdj1000
Colorado
2021 F150 Tremor
Research:
Thank you for this information and pictures. Looking for some ditch light mount options and this is a huge help!
djdj1000
Colorado
2021 F150 Tremor
Any other pictures from folks with the mounts & lights installed or feedback on any of the brackets?
skierd
Fairbanks, AK
21 XL
If I’m seeing this correctly, your mounts are a couple pieces of bar stock drilled out, and the bolts from the light bar brackets run through the thicker parts of the grill? How stable is the mounting; do you get any shake or bounce from the lights when going down the road?
SumGuy
F150 (perpetually on order)
Drugs
Research:
I want these and the tremor overhead switches to run them.
I just need to figure out how.
dre276
andre
NJ
That's correct, I used bar stock as you mentioned. The mounts are pretty stable as I had it on the truck for about a year with zero issues. I would still like to see if there's an aftermarket grill to relocate the lights inside. Maybe the aftermarket Raptor grill would work
