Steering wheel install/alignment off from factory?
Stable68
Stephen
New York
2019 F150, 2021 Lariat on order
Took my truck on its first longer drive the other day and noticed the steering wheel looks like it leans a little to the left. If i hold it to where it looks straight the truck slightly bends right.
Is it possible for the steering wheel to be installed misaligned from the factory? Or could it be an illusion with the gauges?
Ford F-150 Lightning Steering wheel install/alignment off from factory? 451EDCBE-11CE-4ABF-BE9C-FAC551B6FD8E
Your steering wheel can only be installed one way. The steering wheel isn't off, your alignment is.
allJUMPstyle
Keith
Fort Worth, Tx
1964 VW Bug, 1963 VW Doublecab, 2021 F-150 ordered
Definitely an alignment issue.
moates
Matt
2021 Space White F150 3.5 XLT FX4
FF
Mine was the same way! Super annoying. Dealer “fixed” it. Then I leveled my truck and had a local shop align it. It’s perfect now.
Willy
Ontario, Canada
2021 F150 XLT SCrew
Sales
Check your front tire pressures. The left may be too low or the right too high. Not sure what the variance needs to be for the tpms to send an error.
dpbrown02
Derick
New Hampshire
2021 F150 Platinum
Mine is also misaligned about the same amount. Factory equipment must be off. Mine was built in Dearborn on 10/07.
